Turn off / pause synchronisation for a single HAImage
cjchilling
Wed Aug 31, 2016 1:28 pm
Is it possible to turn off or pause synchronisation for a single HAImage pairing?
Christopher Hilling
SpaDental group | https://www.spadental.co.uk/
Michael (staff)
Thu Sep 01, 2016 12:14 pm
Hello Cjchilling,
Unfortunately, current build does not have such option.
In case, if you need to minimize workload to underlying storage during the Synchronization process, you can use "Change Synchronization Priority" button from device's right click menu.
Also, there is a possibility to run a Synchronization process for another device simultaneously (for example, for small Witness in Quorum drive). You can use "Synchronization" button from right click menu for StarWind device which should be synchronized.
Obviously, you always have a possibility to stop StarWind service on the non-synchronized server. But it will stop the Synchronization process for all devices, thus you would have to restore HA later.
