Slow synchronization
sathackr
Thu Aug 11, 2016 5:34 pm
I have the free-for-MCP NFR version of Starwind Virtual SAN and have installed it on two hosts.
The hosts are 2x 12-core supermicro nodes with 6x2TB Sata drives on each. Windows server 2012R2 core edition is configured using software Raid-5 via the Windows dynamic-disk functionality.
Hosts are directly connected via 10Gb ethernet.
I have starwind configured in a 2-node synchronous HA configuration
When I start the initial sync, speeds peak to 5-6Gb/s for a couple of mins, then drop to about 500Mb/s and stay there. I'm trying to sync a 9tb array and don't want to wait days for it to finish.
Is this the intended behavior and can I do anything to change it? Or is there possibly a configuration issue?
I have enabled jumbo frames across the entire path.
Dan
sathackr
Thu Aug 11, 2016 6:16 pm
Nevemind...upon further review my underlying storage is not performing properly. It's the bottleneck.
The spike at the beginning I bet is because Starwind was caching the writes to ram until the buffer filled up.
Al (staff)
Fri Aug 12, 2016 2:15 pm
Hello Sathackr,
Thank you for your post.
It is always a good idea to check underlying storage first :)
Speaking about spike, you are absolutely right. It is StarWind cache doing it's job.
