Virtual san management error
rasmus_lauenstein
Tue Apr 05, 2016 2:48 pm
Hi
I am setting up a trial version of Vsan as a proff of concept before buying.
The software is installed on two virtual windows 2012 r2 servers. I am able to setup the servers to replicate an iscsi storage.
My problem is that I want to use the replicated device in a HA iscsi cluster. But in the management tool I only see "servers" and I think I should see clusters as well.
This pictures shows what i mean:
https://www.informaticar.net/wp-content ... igure1.jpg
Hope that you will be able to help.
PoSaP
Thu Apr 07, 2016 2:33 pm
Hi
As far as I know, you can see only servers, but all HA cluster functionality persists in HA devices.
So you can use fully clustered HA as well.
Dmitry (staff)
Fri Apr 08, 2016 3:09 pm
@PoSaP thank you for your correct answer, we are really appreciate it.
@rasmus_lauenstein as you can see Cluster feature is not implemented in the GUI for last release, because all functionality in HA devices.
And I kindly recommend you to upgrade StarWind to the last version.
You can always find last StarWind version on your customer page https://www.starwindsoftware.com/customer-page
Thank you.
