Mounting Stuck At 100%
Robert4049
Mon Oct 19, 2015 7:27 pm
Hey Guys,
I need some help bad. My drive keeps getting stuck at 100% and I didn't realize the service wasn't running on the other server. I've already removed and re-added the device and I was getting the same error before and after? Please see image attached. I did mark the drive as synchronized
* We also did resubnett that network in the past and I did update the address's in the console.
Vladislav (Staff)
Tue Oct 20, 2015 9:21 am
Hello Robert,
As the troubleshooting step could you please try disabling LSFS deduplication.
Thank you.
Robert4049
Tue Oct 20, 2015 6:55 pm
I found this on the faq? How do you recommend i do this?
How do I disable/enable deduplication?
Currently it is not possible to do so on the fly, but you can disable/enable deduplication during creation of LSFS device: when choosing “thin-provisioned” option, click on “Options” and check or uncheck “deduplication” feature.
Robert4049
Tue Oct 20, 2015 7:16 pm
I just edited the swdsk file and now the device show's non active
Vladislav (Staff)
Fri Oct 23, 2015 2:52 pm
Hello Robert,
Since there could be multiple approaches to the solution for you, may I ask you to contact me personally by creating support request here: https://www.starwindsoftware.com/support-form
Thank you.
Robert4049
Tue Oct 27, 2015 5:23 pm
I'm running on the free version, so i just restored from a backup and running DAS.
Vladislav (Staff)
Fri Nov 06, 2015 8:33 pm
New StarWind build (8716) is available. It contains a lot of LSFS improvements.
Worth trying :)
