Replication fails after rebooting primary node
pjmcghee
Tue Sep 22, 2015 4:19 pm
Hi all,
I have a two node starwind cluster that hosts files for our VMWare environment. When I reboot the primary node (with all VMs shutdown manually in a good clean state) there are four VMs that fail to come back online automatically. It appears that four specific HAs associated with these VMs lose their synchronization and I have to force a sync manually from the secondary node that does a full sync from the primary.
The VMs in question are PPSGIS07, PPSGIS06, POWER16 and FBRAD01
I have attached the logs in case anyone wants to look. But if anyone has any suggestions on how to troubleshoot this, that would be great!
The version is old: 5.8.1889
1.zip
(183.48 KiB) Downloaded 595 times
Vladislav (Staff)
Mon Sep 28, 2015 11:48 am
Hello pjmcghee,
Could you please provide me next information:
- What were the statuses of StarWind devices on both Nodes (“Synchronized”, “Synchronizing” or “Unsynchronized”)
- StarWind logs as well as Windows event logs (Application and System logs in .csv format) from both Nodes, as I am not able to obtain all information from the log file provided before.
- Screenshot of your software ISCSI adapter configuration (static discovery tab).
Could you please also provide me with your StarWind devices layout (you may just select each device in StarWInd console and printscreen it).
Thank you.
