How to rebuild 2nd node
kmax
Mon Aug 24, 2015 12:32 pm
Running V8, lost the array that holds the HA images.
What's the best way to get it back up? I have the starwind config file for the server.
Thanks.
darklight
Tue Aug 25, 2015 9:46 am
Trust me, the best way to get everything done properly is recreating the replicas from the first node from scratch.
kmax
Tue Aug 25, 2015 5:16 pm
Thanks, that is the ticket. While I've been in the replication manager before I didn't recall an option to recreate the device on the secondary.
Fairly slick actually.
Tarass (Staff)
Mon Aug 31, 2015 9:59 am
DarkLight, thanks mate!
kmax, anything else I can help you with? :)
kmax
Tue Sep 01, 2015 6:28 pm
Sure, and anyone else...
Added replicas and synced. Reconnected partner targets from hyper-v hosts. Basically showing duplicates in disk management.
So I'll have a 600GB CSV volume with label HA1 and another 600 GB volume that is basically sitting there unlabeled when I connect via SCSI to the partner.
I'm sure I'm missing something simple.
Tarass (Staff)
Thu Sep 03, 2015 9:04 am
MPIO (Multipath I/O) feature should be installed and enabled for iSCSI devices.
