Hyper V to Workstation 11 Conversion Step
RichRichardson
Tue Aug 04, 2015 9:39 am
Gentlemen,
Seeing as how this is my first post, and as of minutes ago-first attempt at converting Hyper V to VM Workstation 11, I'll get to the point..
I have scoured about and not found a real step by step conversion manual of sorts to accomplish conversions.
Could it be that I've just missed it? It is possible, what I did follow was this set of directions (http://oxfordsbsguy.com/2015/03/02/how- ... rkstation/).
Conversion with V2V seemed to go well, no hangups or error to speak of.
My desires are simple and straight forward enough. Convert my Hyper V images to VM Workstation 11 images.
My 1st attempts failed ( Picture attached). I will assume I did something wrong, there for will ask, does anyone have 'step' that I should follow to ensure a working conversion?
Host systems specification are below... I would be greatly appreciative if anyone could supply me some steps to follow, to achieve the end goal.
Have an outstanding day
Rich
System Information
Time of this report: 8/3/2015, 04:32:45
Machine name: MONSTER_MACHINE
Operating System: Windows 8.1 Pro 64-bit (6.3, Build 9600) (9600.winblue_rtm.130821-1623)
Language: English (Regional Setting: English)
System Manufacturer: ASUS
System Model: All Series
BIOS: BIOS Date: 07/16/14 11:03:16 Ver: 11.04
Processor: Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz (8 CPUs), ~4.0GHz
Memory: 32768MB RAM
Available OS Memory: 32710MB RAM
Page File: 4469MB used, 33360MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.03.9600.16384 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Display Tab 2: No problems found.
Display Tab 3: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: AMD Radeon R9 200 Series
Manufacturer: Advanced Micro Devices, Inc.
Chip type: AMD Radeon Graphics Processor (0x6798)
DAC type: Internal DAC(400MHz)
Device Type: Full Device
Device Key: Enum\PCI\VEN_1002&DEV_6798&SUBSYS_3001174B&REV_00
Display Memory: 6891 MB
Dedicated Memory: 3051 MB
Shared Memory: 3840 MB
Current Mode: 1920 x 1080 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: G276HL
Monitor Id: ACR0300
Native Mode: 1920 x 1080(p) (60.000Hz)
Output Type: DVI
Driver Name: aticfx64.dll,aticfx64.dll,aticfx64.dll,aticfx32,aticfx32,aticfx32,atiumd64.dll,atidxx64.dll,atidxx64.dll,atiumdag,atidxx32,atidxx32,atiumdva,atiumd6a.cap,atitmm64.dll
Driver File Version: 8.17.0010.1404 (English)
Driver Version: 15.200.1062.0
DDI Version: 11.1
Feature Levels: 11.1,11.0,10.1,10.0,9.3,9.2,9.1
Driver Model: WDDM 1.3
Graphics Preemption: DMA
Compute Preemption: DMA
Miracast: Not Supported
Hybrid Graphics GPU: Not Supported
Power P-states: Not Supported
Driver Attributes: Final Retail
Driver Date/Size: 7/15/2015 19:11:48, 1445224 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B71EE2-24D8-11CF-8771-0B10BEC2C535}
Vendor ID: 0x1002
Device ID: 0x6798
SubSys ID: 0x3001174B
Revision ID: 0x0000
Driver Strong Name: oem28.inf:cb0ae41405cb194b:ati2mtag_R575:15.200.1062.0:pci\ven_1002&dev_6798&subsys_3001174b
Rank Of Driver: 00DA0001
Video Accel: ModeMPEG2_A ModeMPEG2_C
DXVA2 Modes: DXVA2_ModeMPEG2_VLD DXVA2_ModeMPEG2_IDCT DXVA2_ModeH264_VLD_NoFGT DXVA2_ModeVC1_VLD
Deinterlace Caps: {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{3C5323C1-6FB7-44F5-9081-056BF2EE449D}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{552C0DAD-CCBC-420B-83C8-74943CF9F1A6}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
D3D9 Overlay: Not Supported
DXVA-HD: Not Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
Monitor Id: ACR0300
Output Type: DVI
DDI Version: 11.1
WHQL Logo'd: Yes
WHQL Date Stamp:
Vendor ID: 0x1002
Device ID: 0x6798
Revision ID: 0x0000
D3D Status: Enabled
AGP Status: Enabled
Monitor Id: ACR0300
Output Type: DVI
DDI Version: 11.1
WHQL Logo'd: Yes
WHQL Date Stamp:
Vendor ID: 0x1002
Device ID: 0x6798
Revision ID: 0x0000
D3D Status: Enabled
AGP Status: Enabled
1st attempt
1st attempt
1st fail.PNG (7.61 KiB) Viewed 20315 times
RichRichardson
Tue Aug 04, 2015 11:14 am
Update:
After a few repeated tries, I have found success now on one VM, but moving to do more.
Although I don't quite understand on step 17 of the prior linked document, it instructs you on 'Selecting a Disk Type' to select SCSI (Recommend).
While all my HDD are Solid state, and give an excellent performance boost- would this really matter?
Starwind personnel, could you please comment on this step? This may be of great help to others.
Rich
RichRichardson
Wed Aug 05, 2015 7:35 am
Update:
After having 1 success at the conversion, I went on to try another with no success.
After having a sucssesful convertion, and starting up Workstation to powerup the new VM, I get this error. Unable to find this 'vmware-vmx.exe' file.
When I convert, I have the V2V read it from one folder and write it to a different folder. IS this wrong?
Rich
Oles (staff)
Tue Aug 11, 2015 4:00 pm
Hello!
Please accept my sincere apologies for a such delayed response.
Right now our R&D guys are investigating your issue. I will provide you with an update ASAP.
Oles (staff)
Mon Aug 17, 2015 10:20 am
Actually, it looks like VMware file is missing. Try reinstalling it, guidance for that can be found here:
http://www.fixerrorkit.com/fix-error/fi ... error.html
