And my biggest problem was that It would take time to spawn a new copy of the image file and that as of right now, I dont know how I could make a new image file available on the target list, through a command-line (so it can be scripted).
But, if, I can setup, with your new plugin, so that when someone connects to a app image file, that they can have read/write ability, and when he disconnects, all the changes are discarded, that would probably solve most of it.
My only question then is, where can I get a copy of the plugin to test my ideas
We have a command line tool called StarPortCtl.exe that is used for test purposes. It can do almoust all the things implemented in StarPort GUI.is there a way to control starport (or ms initiator 2.0) with a command line interface, so that I can script when someone clicks on a app, the initiator connects to the correct target for that app?
I've just sent you the application.DJ_Datte wrote:I would be very interested in that command line utility. You can see my forum-email ? Or I can send you a mail to address you specify.
I'll notify you when it will be ready.And I am looking very much forward to trying out the plugin.
StarPort does not supports binding drive letters to iSCSI devices. So the Windows system will assign the first free drive letter(s) to a new device.One question. Is there a way to secure, so that when I connect with a initiator, I know the drive will appear as a D: for example ?
/Damir
DJ_Datte wrote:Hey
I have structured my ideas how I want my clients to access the ISCSI server images now. Now all I am waiting for is the plugin, so I can continue trials... The CLI has worked wonders for me, thankyou for that Valery =)
Do I need to plan to have the journals on a separate raid just to prevent performance degradation ?
/Damir
Hi Damir,DJ_Datte wrote:And your solution seems to be a very interesting way to solve a few of my problems, I've been quite excited the last week or so, waiting to try out the plugin :)
/Damir
