Starwind and MSSQL on the same server
herman
Tue Jul 07, 2015 5:54 pm
Hello, we are currently testing out Starwind in our lab environment. We are planning to use it for 2-node MS SQL failover clustering. I would like to know if it is acceptable/supported to have both Starwind and MSSQL installed on the same server node? So instead of having 3 servers (2x Starwind, 2x MSSQL), we will only have 2.
Thanks in advance!
Thu Jul 09, 2015 8:15 am
Yes, absolutely supported scenario. That's the way we "workaround" need in Enterprise licenses for SQL Server AlwaysOn AG (Availability Groups). With StarWind replication you can go SQL Server Standard and AlwaysOn FCI (Failover Clustered Instances).
herman wrote:Hello, we are currently testing out Starwind in our lab environment. We are planning to use it for 2-node MS SQL failover clustering. I would like to know if it is acceptable/supported to have both Starwind and MSSQL installed on the same server node? So instead of having 3 servers (2x Starwind, 2x MSSQL), we will only have 2.
Thanks in advance!
herman
Tue Jul 14, 2015 6:29 am
That's great! So if we set up this way, am I right in understanding that the iSCSI initiator should point to the targets as follows (given there are 2 iSCSI target NICs per node).
Node 1:
127.0.0.1
<IP of iSCSI NIC 1 of node 2>
<IP of iSCSI NIC 2 of node 2>
Node 2:
127.0.0.1
<IP of iSCSI NIC 1 of node 1>
<IP of iSCSI NIC 2 of node 1>
Another quick question - as we are using VMware, should we use the PVSCSI controller (instead of the usual LSI Logic SAS) for the drives where the Starwind img files are stored?
Thank you very much!
darklight
Wed Jul 15, 2015 4:08 pm
Hi Herman!
Connections listed seem to be OK to me.
I would recommend to setup the whole configuration as simple as possible. Each additional feature you enable could possibly lead to strange issues and problems. Simple means stable :)
Vladislav (Staff)
Mon Jul 27, 2015 11:48 am
Hope the topic was helpful.
Thank you all!
