no available array's , when adding to scvmm2012
topgunn
Thu Apr 23, 2015 1:02 pm
Hi All,
I'm running the latest free version of Virtual San.
Trying to create a lab situation.
Thing is, if I add a new storage provider, it does not find any array's
As you can see in the picture it does find the Sanwind Server, which is called Hv01.pariha.local, but no available array's to choose from
What can i do about it?
Thx
Tarass (Staff)
Thu Apr 23, 2015 5:19 pm
Did you configure StarWind SMI-S agent according to this document:
https://www.starwindsoftware.com/techni ... -SMI-S.pdf
Could you please attach screenshots of your configuration. Thank you
StarWind Software Inc.
topgunn
Fri Apr 24, 2015 12:07 pm
Thx, I got it to work.
I used the same documentation before, but didnt get it right.
Just started over, and it worked
Tarass (Staff)
Mon Apr 27, 2015 12:01 pm
Glad to hear that!
