ROW with discard crash
digitalis99
Mon Mar 23, 2015 11:05 pm
I'll start by saying this is for the most recent V6 build, so if you guys aren't paying any attention to that any more...then I guess I'm out of luck since V8 doesn't have ROW with discard.
Anyway, I found a bug whereby an initiator that runs out of disk space when connected to a redirect-on-write with discard IBV target causes the entire StarWind service to lock up hard. The crash across all initiators connected to the target is truly spectacular. :roll:
I can provide server logs if you like. I just didn't know if you were touching V6 anymore.
Tue Mar 24, 2015 11:12 am
We don't indeed maintain IBV and V6 codebase anymore but please proceed with a logs and detailed description sent to support@starwindsoftware.com so we could take a look.
We'll move on with a "discard" with V8 at some point so no worries ))
digitalis99
Tue Mar 24, 2015 4:58 pm
Done. Thanks.
Fri Mar 27, 2015 10:33 am
Hi all!
Just a quick update for the community: the logs and all other info was shared with developers team, and currently we are in the middle of investigation process.
