80GB LSFS eats 1TB disk space (disk full)
bofh
Wed Feb 25, 2015 9:13 am
we have starwind 8.0.7509 (2 node 1TB licence)
I created an 80gb device for testing. This device is completely empty.
However, this 80gb devices eats up 1TB disk space (there are a lot of spspx files in the startwind folder). only 51gb of 1.08tb are free on the disk (only this single 80g volume).
seems to be related to snapshots? but snapshot manager gives me only 5 snapshots!
2/24 16:25:18.962 92c Sw: *** DDDisk_ParseControlParameters: Failed: unknown parameter 'SnapshotTimestamp' passed! Parameter will be ignored.
2/24 16:25:18.962 92c Sw: *** DDDisk_ParseControlParameters: Failed: unknown parameter 'SerialId' passed! Parameter will be ignored.
2/24 16:25:18.962 92c Sw: SnapshotTaskDescriptor::StartTask: Snapshot task has been successfully started! Snapshot info - initiator type: 1 ('SnapshotFromStarwind'), token: 6356, uid: 27298812133378 , lun: 0, async: 'no'
2/24 16:25:18.962 92c Sw: SnapshotTaskDescriptor::DBG_TRACE_STATE: Current snapshot task - snapshot name: 'ScheduledSnapshot', state: 'Running', lun: 0, uid: 27298812133378, token: 6356, snapshot initiator: 'Starwind', start time: 1424791518.
2/24 16:25:20.150 12e4 Sw: DDDisk_VSS_IsSnapshotNeeded: Received VSS_IS_SNAPSHOT_NEEDED command. Snapshot will be started by the VSS provider. Token (6356)
2/24 16:25:21.212 12e4 Sw: DDDisk_VSS_IsSnapshotNeeded: Received VSS_IS_SNAPSHOT_NEEDED command. Snapshot will be started by the VSS provider. Token (6356)
2/24 16:25:22.619 12e4 Sw: *** DDDisk_VSS_SnapshotInProgress: Received VSS_SNAPSHOT_IN_PROGRESS command has been failed for snapshot token 0!
2/24 16:25:22.681 12e4 Sw: *** DDDisk_VSS_SnapshotInProgress: Received VSS_SNAPSHOT_IN_PROGRESS command has been failed for snapshot token 0!
2/24 16:25:27.621 12e4 Sw: *** DDDisk_VSS_SnapshotInProgress: Received VSS_SNAPSHOT_IN_PROGRESS command has been failed for snapshot token 0!
2/24 16:25:27.684 12e4 Sw: *** DDDisk_VSS_SnapshotInProgress: Received VSS_SNAPSHOT_IN_PROGRESS command has been failed for snapshot token 0!
2/24 16:25:32.621 12e4 Sw: *** DDDisk_VSS_SnapshotInProgress: Received VSS_SNAPSHOT_IN_PROGRESS command has been failed for snapshot token 0!
2/24 16:25:32.699 12e4 Sw: *** DDDisk_VSS_SnapshotInProgress: Received VSS_SNAPSHOT_IN_PROGRESS command has been failed for snapshot token 0!
2/24 16:25:37.621 12e4 Sw: *** DDDisk_VSS_SnapshotInProgress: Received VSS_SNAPSHOT_IN_PROGRESS command has been failed for snapshot token 0!
2/24 16:25:37.699 12e4 Sw: *** DDDisk_VSS_SnapshotInProgress: Received VSS_SNAPSHOT_IN_PROGRESS command has been failed for snapshot token 0!
Any ideas?
Guy Liu
Wed Feb 25, 2015 1:28 pm
It looks like I am also experiencing this problem.
http://forums.starwindsoftware.com/view ... f=5&t=4053
Max (staff)
Thu Feb 26, 2015 11:46 pm
Hi!
I would recommend removing the device and recreating it using the latest version available on our website as of today.
Please let us know if the issue persists after the steps above.
Thank you!
Max Kolomyeytsev
bofh
Fri Mar 13, 2015 9:01 am
new version solved the problem!
Sat Mar 14, 2015 2:19 pm
Good. Please keep us updated about your evaluation process. Thank you!
bofh wrote:new version solved the problem!
bofh
Thu Apr 30, 2015 10:33 am
problem occured again. 1TB volume (200gb used space) is filled up with 1TB (a lot of spspx files). :oops:
how can I fix this? new installation is not an option!
Oles (staff)
Thu Apr 30, 2015 5:49 pm
Hello bofh!
Could you please submit a support ticket and provide me with next information there:
1) What SW management console build are you using
2) What is the size of your LSFS device
3) What is the size of the storage, on which LSFS device resides
Thank you.
