Alternate Read Only Target for Veeam (VMWare)
atlhivemind
Wed Dec 03, 2014 2:46 am
I have a similar issue to http://www.starwindsoftware.com/forums/ ... f=5&t=3921
I currently have a Starwind v6 cluster and need to set up a Read Only target for use by a Veeam Backup proxy.
The proxy will be connected on separate interfaces from the main SAN to one of the two nodes in the cluster.
Support said this isn't doable-- that is, setting up a "read only" target to an existing device that has a read-write target already assigned to it... with v6 anyway
I've since set up a dev lab with v8 (a single node) and seen that I can set up a target image file as "read only" and seen that it appears possible, at least in a dev environment.
The previous thread re: HyperV said data corruption wasn't an issue for them, but it is obviously a concern for me.
Wed Dec 03, 2014 3:39 pm
1) Upgrade to V8
2) Do what support says you to do to turn R/O mode on. Technically we don't see why VEEAM should even in theory damage your LUN (that's out of our understanding) but YES you can make LUN Read-Only if it makes you happy :)
atlhivemind wrote:I have a similar issue to http://www.starwindsoftware.com/forums/ ... f=5&t=3921
