Description is incorrect on the StarWind service
robnicholson
Mon Sep 22, 2014 3:58 pm
Err... just upgraded from build 6884 to 7185 and noticed the following when restarting the service:
I'm not running the vSphere version! I've not updated the other node yet so I've included how it appeared in build 6884 (sshot-54) and for completeness, how it appears in the services list after upgrade (sshot-55).
Somebody forgot to change a string/switch when compiling? ;-)
Cheers, Rob.
robnicholson
Mon Sep 22, 2014 4:04 pm
The splash screen is wrong too when you reconnect to the server.
robnicholson
Mon Sep 22, 2014 4:11 pm
Managed to screen grab the splash screen. Cheers, Rob.
robnicholson
Mon Sep 22, 2014 4:35 pm
BTW - are the executable the same for StarWind for Hyper-V and vSphere? The following two buttons appears to download the same executable:
Both buttons download a file called starwind-v8.exe with a file size of 33,972,448 bytes.
Cheers, Rob.
PS. Yes, I was checking I downloaded the right version!
Wed Sep 24, 2014 8:17 am
It's an old splash. New version should have no text in black.
robnicholson wrote:Managed to screen grab the splash screen. Cheers, Rob.
Setups are unified (do install or not, use or not some features according to the key applied), XML keys are different.
robnicholson wrote:BTW - are the executable the same for StarWind for Hyper-V and vSphere? The following two buttons appears to download the same executable:
Cheers, Rob.
robnicholson
Wed Sep 24, 2014 8:19 am
Still shouldn't report itself as vSphere version.... the previous build didn't. Cheers, Rob.
Wed Sep 24, 2014 10:16 am
That's for sure. Will be fixed with a next update we'll have soon.
robnicholson wrote:Still shouldn't report itself as vSphere version.... the previous build didn't. Cheers, Rob.
