unknown iscsi initiator
qwertz
Thu Aug 21, 2014 9:47 am
Hi there,
I've got a question about the listed iSCSI Initiator connections for a clustered storage.
I've noticed that i've got 3 additional connections on every target on both clusternodes coming from "iqn.2008-08.com.starwindsoftware:..." on node1 they are from node2 and vice versa.
(Their initiatorname has the targetname included)
To me it seems like some internal connections from starwind, as the connections i've setup via the ms iscsi initiator software are "iqn.1991.com.microsoft:..."
Could you explain me what those connections are / whats their purpose?
Kind regards!
whats their purpose
whats their purpose
Thu Aug 21, 2014 12:23 pm
Yes, you're right!
These are StarWind service connections, which, in fact, are used for sync and HB, and the other ones are the iSCSI client connections configured via the ms iSCSI initiator.
I hope that makes sense.
qwertz
Thu Aug 21, 2014 1:25 pm
:) Yes, this makes perfect sense. I thought HB might be something trivial like ICMP, and Sync something... i don't know... "magical" :roll:
follow up question:
The initiator iqn contains an IP from a subnet that shouldn't be used for sync, but for HB.
Does this play a role here? (meaning don't care about the ip in the iqn)
I just had a look with
netstat -bano | findstr :3260
and there is a connection over this network.
Does HB work over TCP 3260?
Fri Aug 22, 2014 9:18 am
Yes, both sync and HB are using 3260 iSCSI port. The iqn does not actually matter, it can have a node ip and can be serving either sync or HB, no matter which subnetwork is in question, that's just a node identifier.
robnicholson
Fri Aug 22, 2014 3:37 pm
One for the wishlist - a tag indicating what is using the connections:
StarWind sync
StarWind heartbeat
External iSCSI
Or whatever... I wondered the same myself.
Cheers, Rob.
Tue Aug 26, 2014 1:10 pm
That is already on the way.
