Row-back from v8 to v6 possible?
gig4test
Thu Aug 14, 2014 12:59 pm
My SAN is dramatically slowed down after upgrading from V6 to V8. I am getting 6-10MBPS while I was getting 80-120MBPS on a Gb network.
The question is can I safely uninstall v8 and reinstall V6?
Thanks.
Thu Aug 14, 2014 1:50 pm
Well, technically it is possible, so you can give it a try.
We`ll have minor update in a week, so give it a try.
gig4test
Sat Aug 16, 2014 6:40 am
Well we tried it in a test environment. It does not work. If you downgrade from v8 to v6, the iscsi target and device info are all wiped out.
Sat Aug 16, 2014 12:30 pm
Please provide a) configuration file b) log and c) snapshots of what's disabled in the GUI. Zip and send to support@starwindsoftware.com or attach to forum post. Thanks!
gig4test wrote:Well we tried it in a test environment. It does not work. If you downgrade from v8 to v6, the iscsi target and device info are all wiped out.
