MPIO validation failure on V8
superludox
Mon Jul 07, 2014 8:08 am
[Hello,
I am deploying Native SAN for Hyper-V 2-node 2TB Edition at one of our Customer on two Windows 2012R2 servers. Everything looks OK except MPIO validation during cluster wizard. I get a failure during MPIO validation on disk 0,1,and 2 which are not MPIO disk since the are respectively system disk C, Starwind Storage and Backup SATA drive. Is this behaviour normal ?
My certificate reference number for the product is 29312938 (AG). Thanks for your help.
superludox
Mon Jul 07, 2014 9:06 am
Problem solved by applying Windows Update (all possible updates on the two nodes) !? Cluster validation Wizard is now reporting no error on storage :D
Maybe a DSM update ?...
Mon Jul 07, 2014 1:21 pm
I have no idea :D
I saw issues with similar symptoms multiple times and installing all hte Windows updates helps in 99% of cases. Sometimes it was because different boxes had different updates, sometimes because they needed one update or another (they can give different error codes).
Anyway, we LOVE self-supporting customers!
Don`t forgert to keep your softwre up-to-date! Uless it is an Android :D
