L2 Cache Max Size
kspare
Wed Jun 25, 2014 6:11 pm
Whats the maximum size for L2 cache? if I set it to 1tb it crashes? 512mb works fine.
Fri Jun 27, 2014 11:39 am
There's no limit. Should not crash in any case. Brought R&D guys attention on that. Thank you for reporting.
CedricT
Thu Mar 04, 2021 9:08 am
Same problem there. Trying to add cache L2 of 1.5TB and crashes. over 600GB it fails...
Thu Mar 04, 2021 11:55 am
Having so much cache that large may cause data loss in the event of a power outage. Also, L2 cache, by its design boosts only reads; see more about caching https://knowledgebase.starwindsoftware. ... rinciples/. You can boost both reads and writes by putting a HA device on the device intended for the L2 cache.
CedricT
Thu Mar 04, 2021 1:37 pm
ok got it (RTFD)
1To for 6.5 RAM.... That was the trick. I added RAM on the VM and it works perfectly.
I don't get why we could loose any data. If it's a cluster with 2 nodes and a HA device with same parameters L1 and L2 cache (WT).
Thu Mar 04, 2021 1:54 pm
Oops, mixed L2 with L1. I'm sorry. Thanks for the update. Anything else I can assist you with?
