LSFS HA-Image not working properly
fanello
Tue Jun 10, 2014 9:41 am
I've created a LSFS Volume and made it High available. Afterwards I added it to my MS 2012R2 CLuster and made it a csv.
Then I copied one file to "C:\ClusterStorage\Volume3" (The new csv).
The result ist the following: On the node I made the copy, LSFS is 34,5 GB, on the second node, it is only 24GB. The file I copied is ~32GB.
1st node.png (192.61 KiB) Viewed 7944 times
2nd node.png (187.49 KiB) Viewed 7944 times
Logs.rar
(116.16 KiB) Downloaded 702 times
Regards
Benny
Tue Jun 10, 2014 11:59 am
Dear Fanello,
It is expecte behaviour of LSFS devices. LSFS operates on a one node independently from the other node(-s).
Let`s clarify:
The LSFS can create a snapshot on the one of your nodes, but it will not be created on other nodes. Thus your images will have a different size on node 1 and node 2
I hope that helped.
