I have ESXi 5.5 server and I'm testing it with Starwind iSCSI free edition.I found bad behavior with version 8: created LUNs are continuously became disconnected and reconnected. I tried image disk, lsfs and RAMdisk, no difference - problem persist for any LUN type.
Then I uninstalled Starwind from computer, installed v6 free (on same computer - Windows server 2012 R2) and everything is running without problems. After any configuration change system works as expected.
I know, you wrote that v6 is going to out of support and v8 should be certified for ESXi 5.5, but... it seems too buggy for now and unusable. So, even if looks promissing, unfortunately doesn't works.
BTW, is anywhere available documentation for v8? I cannot found any...
Thank you.
Pavel.
