cannot share drives/images
Locked
gooper
Fri Apr 08, 2005 9:28 am
I just downloaded StarWind yesterday and tryed to connect to the RamDrive: successfully
after that i tryed to use an image file which did not work.
I have already found that the image should better be in the install-directory of StarWind.
but no matter if i wanted to let the UI create my image file nore if i used mksparse.exe, i do not have any images files in the UI to chose als device to make accesible.
I always get the error: Cannot add device. Device test failed for 'ImageFile0'.
what am i doing wrong?
mfg
Tobias
Val (staff)
Fri Apr 08, 2005 10:19 am
gooper wrote:Hi,
mfg
Tobias
Hi Tobias,
You need to change the ImageFile default directory to the path where your disk images are stored.
Open the StarWind.conf file and change the following line:
addplugin -module:"ImageFile.dll" -symlink:"ImageFile" -type:"Image file" -imagedir:"d:\images|cdfv|images|dat,list"
You can add several -imagedir parameters to access several folders.
We'll fix the issue with -imagedir that points to a non-existent directory in the next build.
Valeriy
gooper
Fri Apr 08, 2005 2:32 pm
The default directory, where StarWind expectes the images is the Installdirektory of StarWind, or am i wrong?
gooper wrote: I have already found that the image should better be in the install-directory of StarWind.
even when i change the line in the config-file, i do not find any image-files th choose in the UI.
mfg
Tobias
Val (staff)
Fri Apr 08, 2005 2:36 pm
gooper wrote:The default directory, where StarWind expectes the images is the Installdirektory of StarWind, or am i wrong?
mfg
Tobias
Tobias,
It seems there is a configurational issue.
Please send me your StarWind.conf and the StarWind Service log file for the session.
Also please specify where your image files are located (the directory path)
Valeriy
Locked
