v8 RC File Browser Access Issue
microfoundry
Mon Apr 28, 2014 11:33 pm
Greetings - currently running 8.0.6441 and I just noticed one of my two nodes errors on the creation on an image file and logs the following error:
FileBrowser: Could not create image : insufficient rights!
Additionally the File Browser window does not display any data (drives/folders/files) while trying to create a virtual disk. FWIW, it does display data if trying to create a Virtual CDRom.
TIA,
Terry
Best Regards,
Terry G Phillips
Bohdan (staff)
Tue Apr 29, 2014 10:13 am
Hello Terry,
please send your StarWind.cfg file and StarWind logs to beta-testing@ e-mail.
microfoundry
Wed Apr 30, 2014 11:07 pm
Hi Bohdan - just for kicks, I compared the config files from my 2 nodes and discovered the <filebrowser> sections were not the same
Before:
<filebrowser>
<imagedir path="*" flags="cmdfv" alias="VTLs" extensions="swdsk"/>
<imagedir path="*" flags="cmdfv" alias="VTapes" extensions="VTape"/>
<imagedir path="*" flags="cdmfv" alias="Event Logs" extensions="txt,log"/>
<imagedir path="*" flags="cdmfv" alias="Headers" extensions="swdsk"/>
<imagedir path="*" flags="v" alias="My Computer" extensions="*"/>
<imagedir path="*" flags="v" alias="Image Files" extensions="img,dat"/>
</filebrowser>
After (matching my good node):
<filebrowser>
<imagedir path="*" flags="cdmfv" alias="My Computer" extensions="*"/>
<imagedir path="*" flags="cdmfv" alias="Image Files" extensions="img,dat"/>
</filebrowser>
I'm not sure how/when/why the config file got off into the weeds, but the change fixed my issue.
Care to share the official definition of the flags attributes?
Thanks again!
Best Regards,
Terry G Phillips
Mon May 19, 2014 6:34 pm
V8 is out. Please update. Thanks!
