multiple issues v8 rc
Locked
barrysmoke
Wed Apr 16, 2014 1:46 am
I just installed V8 RC , and had these issues:
issue 1) can't mount iscsi targe locally, session initiates, and shows connected, however disk information doesn't show up in ms iscsi initiator screen
issue 2)remote connection of iscsi shows disk in disk manager, but when trying to create simple volume, I get Data error( cyclic redundancy check).
issue 2 cyclic error
issue 1 remote devices view
issue1 local iscsi devices
barrysmoke
Wed Apr 16, 2014 5:45 am
data error, (cyclic redundancy checks) went away once I deleted the 10TB target device, and recreated just a 1TB device.
barrysmoke
Wed Apr 16, 2014 5:56 am
issue3) logfile error
Alex (staff)
Wed Apr 16, 2014 10:42 am
Starting from the last issue: do you have enough free disk space on disk C: on the machine where Management Console is running?
Could you please send logs from StarWind service? They are located in "c:\Program Files\StarWind Software\StarWind\logs" directory.
Alexey.
barrysmoke
Wed Apr 16, 2014 9:10 pm
log file was a filled up c:
I had run iometer against the OS drive, and it created a file that filled up the remaining free space...ooops..
barrysmoke
Tue Apr 22, 2014 5:29 pm
I still haven't resolved the local iscsi mount issue yet.
Any advice?
barrysmoke
Tue Apr 22, 2014 5:49 pm
I know bohdan was looking at this, and I'm not sure if he logged in and changed anything, but I just tried reconnecting to the target, and in the microsoft initiator, devices view, it showed correct information now...and everything is working.
If he did change something, I would like to know what, otherwise ghost in the machine.
Mon May 19, 2014 6:34 pm
V8 is out. Please update. Thanks!
kevin12
Wed Sep 24, 2014 12:53 pm
anton (staff) wrote:V8 is out. Please update. Thanks!
i want to update v8 rc. would you please guide me that how to update it easily
Wed Sep 24, 2014 7:23 pm
1) Put down node #1 StarWind Service
2) Upgrade StarWind for it (just install new version over old one, setup will do everything)
3) Power up StarWind service for #1
4) Re-sync (fast or full) would happen for node #1
5) Repeat 1..4 for #2, #3 etc
== thread closed ==
Locked
