StarWind iSCSI v8.0 RC - Virtual Tape Libary
thomas bloss
Wed Mar 26, 2014 7:34 pm
i tried to install a VTL, after creation i create a Media and the dialog-box will not stop to pop-off, so i have to restart the Server, after that the VTL was inactive and no Media was mounted, start the Create media Dialog - same as before . . . . . . :(
is there something wrong in the RC or missunderstud i the Funktion ?
regards
T.
Bohdan (staff)
Fri Mar 28, 2014 12:19 pm
Right now there is not media mount indication in StarWind Management console. That will be fixed before release. To check if the media is present you should connect the target via iSCSI initiator and make sure that tape device exists.
As for the tape creating and service restart, please zip and send us StarWind logs to check what's wrong.
