AKnowles
Mon Mar 24, 2014 5:54 pm
Just a quick FYI ... after a reboot the LSFS disk I had was taking too long to mount. I mean about 5+ minutes and only 1%. So, I gave up and deleted the LUN and moved on.
I've seen other reports of long mount times, but this was a first for me. How long should a LSFS disk really take to mount? Is it by design that it takes longer than a thick LUN? If so, LSFS LUNs are not something I could recommend for a production environment. FWIW, there was no dedup or L2 caching on this LUN.
Mon May 19, 2014 6:33 pm
V8 is out. Please give it a try. Thanks!
Sun May 25, 2014 8:07 am
Thank you! Your efforts are appreciated.
AKnowles wrote:I'm downloading the release and will give it a try and let you know my results.
SirHandyMan
Thu Jul 03, 2014 9:39 pm
I experienced the same thing running version 8.0.6884.
After a proper shut-down and reboot of both StarWind servers, my LSFS volume took 8+ hours to mount.
Fri Jul 04, 2014 11:11 am
There's set of issues related to a slow reading from LSFS volumes (especially if you use fast block back end). We're applying some critical mods to LSFS so please stay tuned a couple of more days and you'll have something to play with
SirHandyMan wrote:I experienced the same thing running version 8.0.6884.
KLSsandman
Mon Jul 28, 2014 2:21 pm
We have the same version and have this problem along with extremely slow read speeds. Any eta on the fixes?
Many thanks
Simon
Mon Jul 28, 2014 2:22 pm
Build facing these issues would be out of QA this week.
KLSsandman wrote:SirHandyMan wrote:I experienced the same thing running version 8.0.6884.
Many thanks
Simon
KLSsandman
Mon Jul 28, 2014 2:32 pm
Brilliant, can't wait to get this applied, had to storage vmotion everything onto a flat disk but thats taken nearly a week and we still have 12 servers left!
Many thanks
Simon
anton (staff) wrote:Build facing these issues would be out of QA this week.
Many thanks
Simon
Mon Jul 28, 2014 2:49 pm
That's insane...
