V8 RC long mount time
Ironwolf
Fri Mar 07, 2014 5:46 pm
Recently load up RC,
I've seen a great number of improvements, :D
the 1st lingering problem I have seen in testing so far is long mount time of one of the LSFS lun's this is the same thing I had seen on V6 with dedup LUNs one of them always takes forever to mount on a reboot
The testing LUN size is only 10GB so it only took about 10-11 min, but on larger LUNs in V6 it could take 45min or more
127.0.0.1-3261-service-starwind-20140307-083101.zip
(12.73 KiB) Downloaded 1164 times
Long Mount time 10GB size.PNG (65.24 KiB) Viewed 13745 times
Bohdan (staff)
Tue Mar 11, 2014 5:06 pm
Thanks.
Analyzing the logs...
Bohdan (staff)
Wed Mar 12, 2014 2:38 pm
It is possible for you to edit StarWind.cfg file, set <LogLevel value="3"/>, restart StarWind service, reproduce the issue and send us that log?
Ironwolf
Wed Mar 12, 2014 8:13 pm
Of course I was not able to fully reproduce the issue related to this, it does seem dependent on the amount of data inside the LSFS and how much deleting copying I had done to the LSFS LUN, empty disk took little time to mount. Yet in all cases while mounting little to no disk activity.
Larger LSFS.zip
(15.07 KiB) Downloaded 1151 times
LSFS Long mount time 10min 1%.PNG (73.37 KiB) Viewed 13613 times
LSFS Long mount time 8min 1%.PNG (75.58 KiB) Viewed 13611 times
Ironwolf
one more file
Small 10GB LSFS.zip
(24.52 KiB) Downloaded 1285 times
Bohdan (staff)
Thu Mar 13, 2014 4:45 pm
Unfortunately this is not the <LogLevel value="3"/> log and that's why we can not find the root of the problem... L3 logs may help to find what's wrong.
