Problem setting up storage pool
robnicholson
Fri Feb 21, 2014 6:25 pm
In the following screenshot, I am just in the middle of creating a new folder on the E: drive (E:\SAN) for the storage pool but haven't pressed CR yet. However, when one does press CR it a) creates E:\SAN but b) closes the dialog choosing E:\ incorrectly as the path. Pressing CR whilst creating a new folder should not close the dialog - it should simply create the folder and leave you in the dialog allowing you to then select E:\SAN:
To make matters worse, you are then thrown straight into the main console and I've gone through every menu item and can't see where you change this page. I would have expected something on the options menu.
Cheers, Rob.
Fri Feb 21, 2014 8:50 pm
Nice :( Thank you for reporting we'll take a look ASAP.
Mon Feb 24, 2014 3:14 pm
Devs report this bug as FIXED. Please re-check with RC. Thanks!
mahuan1688
Tue Feb 25, 2014 1:26 am
where is rc?is alrready download?
Tue Feb 25, 2014 2:13 pm
Unfortunately no. But we are doing our best to get it really soon. I`m pretty sure that you`ll be notified once it`ll be released.
