WindowsTechBlog
Mon Feb 03, 2014 3:00 pm
Hello all,
Recently i have downloaded the Trial Version of StarWind iSCSI SAN & NAS for my Windows Server 2012 R2 Hyper-V cluster test environment. I have to 2 Fileserers and on both servers i create an .img file for the virtualdisk (for the hyper-V storage). Now i have to slect a NIC for Heartbeat and sync. I have only 1 NIC in each server. I cannot select a NIC, is this because i have only one NIC. It is for a test network and i do not have enough hardware to create 2 NIC's in each server. How can i fox this?
Mon Feb 03, 2014 4:51 pm
Hi!
Actually you should have at lease two NICs on each server to run HA. As the work around you can try to virtualize the network card , but that is supported for test labs only.
WindowsTechBlog
Mon Feb 03, 2014 9:44 pm
Hi Anatoly,
Thanks for your respone. It's not possible to create an another workaround? I have inly physical servers with one NIC, i am not running my servers on Hyper-V.
WindowsTechBlog on Sat Feb 08, 2014 12:41 pm, edited 1 time in total.
Mon Feb 03, 2014 10:30 pm
Sure. Create a set of VLANs on top of your physical LAN and proceed with your eval.
WindowsTechBlog
Wed Feb 05, 2014 5:35 pm
Hi anton,
First, thanks for your reply. The two servers are now both with 2 NICs. Now I can be in the "Add Device Wizard" only one NIC, why is the other NIC is not visible? How can I fix this?
See the attachments.
Sorry for my bad English, i am from The Netherlands.
- Screenshot of my network interfaces and the add device wizard
- Add device wizard.png (39.26 KiB) Viewed 20406 times
Thu Feb 06, 2014 9:51 am
In most of cases we can see such behavior when something else (like MS target) is reserving the NIC, can you doublecheck if this is so please?
WindowsTechBlog
Sat Feb 08, 2014 12:40 pm
Hi Anatoly,
Thanks for your response! I have removed de iSCSI Target Server role from the server, and now i am able to select 2 NIC's!:D Thanks for the solution! Now i can proceed with my testing environment!
- Problem solved!.png (17.92 KiB) Viewed 20364 times
Sat Feb 08, 2014 5:48 pm
Excellent! Please keep us updated about your progress
Wed Feb 19, 2014 11:47 am
You`ll probably have a split brain, or just unsynchronization of devices. Anyway, it is not hte best idea to change IPs on the fly.
