Starwinds8-Beta2 Can't create Asynch Partner
kmorrissey
Tue Dec 10, 2013 6:08 pm
I have installed V8 Beta 2 on three Windows Server 2012 machines, it's the only thing installed.
I built a Synchronous 2 way HA group between the first two and it's working.
Now I'm trying to add the third as an asynchronous partner but I keep running into the same issue.
When it goes through the creation process it fails at "Create device header on partner host", and I get the pop-up "HA Device initialization for the second partner node failed.
All three hosts are added to the management console and are connected. As you can see 2 files are created on the correct drive on the third machine and after I hit ok on the error and cancel the wizard I will see the new target appear under the third host it's just not tied to anything.
I have also tried manually creating a target and using that during the HA wizard but it still fails.
In this case all the machines are on the same switch and subnet.
The third machine actually has twice as much storage as the first two so I know it's not drive space.
Any suggestions?
Kenny
Bohdan (staff)
Tue Dec 24, 2013 1:14 pm
It will be fixed in one of the next builds.
