divbert
Thu Nov 21, 2013 2:10 pm
I try to convert a Linux.vmdk autogrowable to vhd autogrowable. The file size is 20 GB.
After serveral hours I get the error message above. Any ideas?
Thanks a lot,
divbert
- converting history
- V2V_001.jpg (31.64 KiB) Viewed 10922 times
- Version screen
- V2V_002.jpg (20.04 KiB) Viewed 10921 times
Fri Nov 22, 2013 10:41 am
Can you confirm that you have enough of free space on the volume where the output of conversion is located?
divbert
Fri Nov 22, 2013 11:18 am
There is more than 170 GB of free space. At the beginning a file with approx. 20 GB is generated in the destination folder.
I have seen that the original file can grow to a max. of 400 GB (autogrowable). Can this be the problem? Otherwise I get no Information from the pc where the converter is running that there is not enough space or any problem with.
Mon Nov 25, 2013 3:04 pm
Thank you
The update whould appear in next iteration of the software (it should come up simultaneously with v8 of iSCSI SAN)
