starwind config help ?
fbifido
Wed Nov 13, 2013 4:48 pm
I have one target with 3 LUN, and i tried to make it accessible only to my esxi1 server only, but lock myself out.
I tried to disable all other access to the target, but not knowing that the defaul rule was not for the traget but for the management.
but why the management rule is under the target settings?
How can i get back the default access policy ?
this is from the starwind.cfg file
<acltable>
<DefaultAccessPolicy value="allow"/>
<aclrecord name="esxi01" source="192.168.6.2|192.168.7.2" destination="iqn.2008-08.com.starwindsoftware:storage01-dunncox" interface="192.168.6.1|192.168.7.1" action="allow"/>
</acltable>
When i start the management GUI, select connect, the popup message say "(127.0.0.1): 3261 connected", but it halt at this point.
I have to go into taskmgr to kill it.
Now it's telling me i need a lic. I redownload the program & lic file, but that lic file failed to install.
fbifido
Wed Nov 13, 2013 5:03 pm
from the ConfigUpdater.log
Cannot open 'StarWind.conf'.Creating new document
Error parsing file 'StarWind.cfg.bak' : Ü"!a: S
Stopping update process
fbifido
Wed Nov 13, 2013 5:31 pm
please see log file
starwind-20131030-143720_003.zip
starwind-20131030-143720.zip.003
(200 KiB) Downloaded 1879 times
starwind-20131030-143720_002.zip
starwind-20131030-143720.zip.002
(200 KiB) Downloaded 1796 times
starwind-20131030-143720_001.zip
starwind-20131030-143720.zip.001
(200 KiB) Downloaded 1738 times
Bohdan (staff)
Wed Nov 13, 2013 5:46 pm
ACL does not affect the management interface.
Default ACL policy can be changed in StarWind.cfg file
It looks like service crash. Do you see minidump files in StarWind directory?
fbifido
Wed Nov 13, 2013 5:47 pm
starwind-20131030-143720_004.zip
starwind-20131030-143720.zip.004
(2.4 KiB) Downloaded 1793 times
fbifido
Wed Nov 13, 2013 5:50 pm
Bohdan (staff) wrote:ACL does not affect the management interface.
Thanks, what I did was
<aclrecord name="DefaultAccessPolicy" action="allow"/>
and now I have 2 DefaultAccessPolicy in the management GUI.
Yes re: dump file, 2 of them, one 7GB and the other is 1GB
turkina
Thu Nov 14, 2013 12:36 am
It did on my box. Added Access rights for my VMware cluster to see one target, my Hyper-V hosts to see another target, then set the default access policy to deny. Could no longer manage Starwind. Once I shut down my VMs and rebooted the server Starwind was running on, the default access policy was back to Allow and all we good again.
fbifido
Thu Nov 14, 2013 2:50 pm
One of my LUN's is not mounting, and i don't see any tools or option to do a check on the LUN.
I let it run for more than a day.
the other 2 LUN's came up under 3hrs, so why is this taking so long?
http://tinypic.com/r/111v2hf/5 <---- full picture
What can i do ?
fbifido
Thu Nov 14, 2013 4:49 pm
I just deleted this LUN and re-created it.
I had to stop the iSCSI SAN service to delte the files.
I lose alot of test VM's.
Starwind need a way to repair lsfs file system, so that they can mount very fast.
Bohdan (staff)
Thu Nov 14, 2013 4:51 pm
The problem is fixed. I'll update the beta build ASAP.
fbifido
Tue Nov 19, 2013 6:32 pm
When you update the beta build, let us know.
because all we see is Beta 2, on the download page.
Bohdan (staff)
Thu Nov 21, 2013 2:12 pm
Sure.
Thanks for the patience.
Bohdan (staff)
Fri Nov 22, 2013 7:03 pm
The build has been updated.
http://starwindsoftware.com/tmplink/StarWindBeta.exe
Please check the fix for the ACL issue.
Could you please also check the update process from v6 to v8? All devices types should work properly, but Snapshot&CDP, Mirror and DDdisk devices have restricted management functionality. There may be issues with LSFS in synchronous replica configuration. Single LSFS devices should work properly, as well as LSFS snapshots.
Update from previous beta builds may not work correctly.
Also we are interested in performance results for Synchronous replica devices based on thick images.
