kspare
Fri Jan 03, 2014 9:22 pm
We are seeing alot of these errors with the latest beta:
1/3 14:33:39.638 1244 Ssc: *** SscScsi_InquiryHandler: INQUIRY VPD page 0xb1 is not supported!
1/3 14:33:39.998 1244 Ssc: *** SscScsi_InquiryHandler: INQUIRY VPD page 0x86 is not supported!
1/3 14:33:39.998 1244 Ssc: *** SscScsi_InquiryHandler: INQUIRY VPD page 0xb1 is not supported!
1/3 14:33:40.420 1244 Ssc: *** SscScsi_InquiryHandler: INQUIRY VPD page 0x86 is not supported!
1/3 14:33:40.420 1244 Ssc: *** SscScsi_InquiryHandler: INQUIRY VPD page 0xb1 is not supported!
1/3 14:33:40.935 1244 Ssc: *** SscScsi_InquiryHandler: INQUIRY VPD page 0x86 is not supported!
1/3 14:33:40.935 1244 Ssc: *** SscScsi_InquiryHandler: INQUIRY VPD page 0xb1 is not supported!
jcrowe
Wed Jan 08, 2014 1:52 am
Is UNMAP implemented yet? I created a deduplicated drive, and now I have many .spspx files. There are hundreds of entries in the log '*** DDDisk_Dispatch_WriteSameAndUnmap: WriteSameUnmap - Not implemented yet!'
Even after using VMotion to move a VM off this storage, the space used by the .spspx files did not go down.
Bohdan (staff)
Wed Jan 08, 2014 9:48 am
kspare wrote:I can't create a thin provisioned virtual disk. I have it set to 21tb and it comes with with an error: Specified storage is too big. the max allowed size of storage is 0mb.
If I go 10tb I get: Specified storage can not be mounted. there is not enough free memory for cachine device meta data. the max allowed is 0
If I go 5tb I get the same error as above.
I get the same error for 1tb as the first error.
Thick works fine.
It checks the free physical memory (RAM). What amount of free RAM do you have on that machine?
Please make a screenshot of the corresponding page of Windows Task Manager, reproduce the issue, zip StarWind logs (default location is C:\Program Files\StarWind Software\StarWind\logs) and send all this info to beta-testing e-mail.
Thank you!
sbozhko
Mon Jan 13, 2014 11:07 am
Also similar problem...
If I
create lsfs device on volume > 2TB - i get device with state "Failed!" with log:
1/13 12:59:30.120 f70 Sw: *** DDDisk_ControlRequest: Unsupported control command 'AttachDeviceNotify:' in current mode!
1/13 12:59:30.136 f70 conf: Target [0x0000000000F93070] 'iqn.2008-08.com.starwindsoftware:r00-sw-212.hq.vlmrk.corp-storage3' has been created, 1 devices attached.
1/13 12:59:30.230 dc4 Sp: *** CStarPackCore::FormatNewStorage Cannot create such a large device VMap[877243472 > 714430123]. Max allowed [1463152891904] bytes
1/13 12:59:30.230 dc4 Sp: --- CStarPackCore::FormatNewStorage() (line #5248) 50
1/13 12:59:30.230 dc4 Sp: --- CStarPackCore::CreateEx(0x000000009D2EF610) (line #2701) 50
1/13 12:59:30.230 dc4 Sp: *** SpCoreObjectCreateFromParams 50 *ppCore->pCore->Create( 0x000000009D2EF600 ) 2637100560
1/13 12:59:30.230 dc4 Sp: --- SpCoreObjectCreateFromParams(0x000000009D2EF600, 0x000000009D2EF610) (line #4472) 50
1/13 12:59:30.230 dc4 Sw: *** DDDisk_MountAsync: Create SP object failed, status ( 50 ) - 'General failure'.
If i create lsfs device on volume < 2TB and expanding volume beyond 2TB
after what - device work correctly.
btjtaylor
Thu Sep 18, 2014 9:54 pm
hello, I am trying to install the beta, but I get an error when I use the "sw8_26022014_betatest_betatest.swk" license file:
"Error occurred while checking license key file"
Please help!
Ben
- starwinderror.png (144.59 KiB) Viewed 44414 times
Thu Sep 18, 2014 10:04 pm
Beta program is complete. Apply for release of V8 (updated many times BTW since the data of the original release couple of months ago).
== thread closed ==
