I have a two node HA setup with both servers being linked via two 10Gb NIC's. When my two servers synchronize the NIC's are only running at about 1.8 Gbps each. I would have expected to see both NIC's on the PINS when a synchronization occurs, which is not the case. What should be the expected behavior?
Chris
