HA connection lost
desmotre
Tue Oct 01, 2013 3:27 am
I use Starwind version 6.0.5713. I faced HA connection lost without any network lost or storage error.
Is version 6.0.5713 includes update "20.08.2013"?
I think my errors may correct patch number "20.08.2013".
"HA device become not synchronized without any obvious reason like failure of network or of underlying storage. "
http://www.starwindsoftware.com/forums/ ... tml#p16541
Tue Oct 01, 2013 3:18 pm
What exaclt do you mean? Have you lost the storage or the SW Mgmt console could`nt connect to the service on some host?
desmotre
Wed Oct 02, 2013 1:19 am
Hi Anatory,
When I use hyper-v live migration on WSFC, all of Starwind HA datalink for WSFC CSV is missing.
But all of other HA disks are not affected.
Of course, any kind of storage, switch, network adapters and OS are working properly.
What is the cause do you think?
Wed Oct 02, 2013 8:50 am
I think that this is weird, and that shouldn`t happen.
May I ask you to provide me with next information:
· StarWind logs from all problematic SAN boxes
· Windows Application and System logs (in *.csv format) from all problematic SAN boxes
· Detailed network diagram of SAN system
· Description of the actions that were performed before/at the time of the issue (I mean, if the Live Migration was teh only thing that was happening on hte time of the issue?)
Thank you
joerg
Tue Mar 24, 2015 10:22 pm
Hey,
I have the same issue. Have you solved the problem?
best regards
Joerg
Fri Mar 27, 2015 10:25 am
That was like two years ago, and I do not remember exactly, but as far as my bell rings - that was some hardware related issue.
So, you are facing the same issue with StarWind v8? Have you checked the StarWind and Windows logs regarding some errors or warnings, that are not StarWind related?
joerg
Fri Mar 27, 2015 1:17 pm
well... my V8 installation did not reached that point (http://forums.starwindsoftware.com/view ... f=5&t=3948).
So i don't know if I (would) have the same issue.
Maybe desmotre, who posted the issue first, knows a solution or where the problem was.
regards
Joerg
PS.: I will have a deeper look into the starwind and windows log-files when this behaviour occurs next time and keep this thread updated
epalombizio
Fri Mar 27, 2015 1:40 pm
Count me in as having this issue as well.. Running v8
Vladislav (Staff)
Tue Mar 31, 2015 12:44 pm
Anatoly (staff) wrote: May I ask you to provide me with next information:
I think we need to take a closer look at your logs to be able to provide you with any comments regarding this issue.
