upgrade V6 –> V8 DeDup notes Feedback
Ironwolf
Wed Sep 18, 2013 5:20 pm
Regarding DE Duplication your notes on installing V8 states limited functionality for older DDisks, my assumption was that it would at least be read only or reduced performance the reality is it will only display the DDisk as non-active and not usable. “Disks need to be converter to img prior to install” needs to be added to the notes
Reloading V6 seems to restore original functionality, allowing for the conversion, luckly both V6 and V8 remembers the configuration  :)
Wed Sep 18, 2013 5:23 pm
We'll support existing devices of course. Just (maybe) disable ability to create old-format ones with V8.
Ironwolf
Wed Oct 23, 2013 8:12 pm
Beta-2, Dedup from version 6 are still not working at least for me, my current solution is to copy the contents out and into a new Thick IMG Lun that does work in V8
DDisk non-active event log.PNG (133.57 KiB) Viewed 11192 times
DDisk non-active detail.PNG (126.57 KiB) Viewed 11196 times
DDisk non-active.PNG (138.96 KiB) Viewed 11197 times
Mon Nov 04, 2013 10:14 am
Thanks for the feedback.
I can confirm that this was the best solution for your case.
Currently we are working to make upgrade process painless.
