Alex (staff)
Thu Oct 10, 2013 11:58 am
1) We have fixed the issue with cache settings for the new partner. Now L1 cache mode and cache size are used when partner device is created automatically.
If other cache settings or L2 cache is needed on partner device, it need to be created manually. Then just select this device as a partner in replication manager.
2) We'll add this option to the new wizard!
Alexey.
Omnividente
Thu Oct 10, 2013 12:22 pm
Alex (staff) wrote:1) We have fixed the issue with cache settings for the new partner. Now L1 cache mode and cache size are used when partner device is created automatically.
Does not work.
I created a virtual disk cache L1 5000mb, then added a replication partner. I do not see the cache peer.
First Node / Parter
jwordtmann
Thu Oct 10, 2013 4:32 pm
Bohdan (staff) wrote:
It is fixed. The beta build will be updated by the end of the week. I'll post the notification in this topic.
WOOHOO!
Thank you!
Bohdan (staff)
Thu Oct 10, 2013 4:34 pm
Omnividente wrote:
1.Sata
2.SoftWare
3.64kb
OK. Here are the results from our testlab for 3 SATA disks windows software raid0 (striped volume) on Windows 2012R2.
1.HDD 2.Virtual disk-thick provisioned on this HDD and 127.0.0.1 target portal without cache
- raid 0.jpg (223.39 KiB) Viewed 30860 times
We don't observe such significant performance loss.
What RAID software do you use?
Omnividente
Thu Oct 10, 2013 5:47 pm
Intel RST(ich10)
ok test ssd disk without raid windows server 2012 r2
test ssd disk in my home computer without raid (Windows 8.1)
what am I doing wrong?
- starwind-20131010-210955.rar
- Windows 8.1 new instalation
- (5.42 KiB) Downloaded 1118 times
Mon Oct 14, 2013 11:18 am
Hi!
Just wanted to give the community and update: currently we are emailing with Omnividente. As far as we will have any result we will definitelly post it.
awedio
Mon Oct 14, 2013 4:02 pm
How about some or one of the following:
1) Documentation
2) Videos
3) NAS Configurator
Mon Oct 14, 2013 6:48 pm
We`ll have it on the day of release
Bohdan (staff)
Tue Oct 22, 2013 6:52 pm
The beta build has been updted.
Quick notes:
A lot of small fixes and updates, several new features.
Log-structured File System container: fixes and performance improvements.
Flash cache: fix for the issue when non-default path has been used for L2 cache storage device.
Core: VAAI support for single-node devices and devices with synchronous replication.
Scale-out cluster: organize your servers to SAN cluster and create multi-node devices across the cluster easy.
Ironwolf
Tue Oct 22, 2013 8:42 pm
Installed over pervious beta, 5903 -> 6049, everything seems fine so far
- install assertion.PNG (37.59 KiB) Viewed 30507 times
fbifido
Tue Oct 22, 2013 9:53 pm
Bohdan (staff) wrote:The beta build has been updted.
Quick notes:
Is this update still beta 1 and not beta 2?
is it located at the same beta 1 download link?
