guillermo.lozano
Mon Sep 02, 2013 2:17 pm
I’m trying the tape redirector.
I managed to connect the iSCSi Initiator on a Win Server 2008 R2 without problems, but I do not see the device listed on the device manager.
What might be the problem?
I’m sharing one standalone tape drive installed on a physical Windows 2008 R2 server.
Attached is the log file.
Thanks.
Guillermo.-
- Log.zip
- Log
- (11.28 KiB) Downloaded 1055 times
Mon Sep 02, 2013 9:28 pm
Hi!
Have you installed the driver for it?
guillermo.lozano
Mon Sep 02, 2013 10:42 pm
Hi Anatoly!
Incredible suggestion, it worked! is there an installation manual? I haven't found any...
I'll try how it works and get back with the results.
Best Regards,
Guillermo.-
guillermo.lozano
Tue Sep 03, 2013 1:44 pm
Hi! it's working properly now, with the IBM ITDT Tool the test are beign performed correctly.
Now i have to see iv Veeam v7 sees and uses the tape drive correctly.
Is there a license i need to purchase to use commercially Tape Redirector?
Thank you for the help.
Best Regards,
Tue Sep 03, 2013 8:50 pm
You really need to follow your tape drive manual rather then StarWind one. So StarWind just blindly redirects (well... almost) SCSI traffic from one machine to another -
we have no idea what tape drive (loader) you use and what you do to configure it.
guillermo.lozano wrote:Hi Anatoly!
Best Regards,
Guillermo.-
Tue Sep 03, 2013 8:51 pm
Good! Now try to restore everything in a test mode to be sure you'll be fine @ some point.
Oh, nice to know
Nope. We don't accept money for this kind of stuff. Just use it
guillermo.lozano wrote:Hi! it's working properly now, with the IBM ITDT Tool the test are beign performed correctly.
Best Regards,
