Can't connect
daku97
Mon Aug 19, 2013 1:54 pm
All, i'm sure this may be a simple issue but it eludes me. I have installed the StarWind Tape Redirector on a Windows 2012 physical server with a LTO tape drive. My goal is to provide access to the tape drive to a Wind 2008 R2 VM on the same machine. This VM will run Backup Exec 2012. I have installed the software on the Windows 2012 physical server, created a target which in-turn created a device. All looks good until i go to the 2008 VM, open the ISCSI Initiator properties and try to connect. I get "Connection failed"
I have verified there are no firewalls blocking the traffic, one flat network. All services are started and see no errors in event logs or applications.
Any guidance wold be appreciated.
daku97
Mon Aug 19, 2013 2:36 pm
Additional logs
8/19 8:17:51.138 d48 Srv: StarWind Tape Redirector v5.8.0 (Build 20120319, [SwTredir], Win64)
8/19 8:17:51.138 d48 Srv: Built Mar 19 2012 15:44:01
8/19 8:17:51.138 d48 Srv: Windows v6.2 Datacenter Edition (Build 9200)
8/19 8:17:51.138 d48 Srv: System CPU count: 8
8/19 8:17:51.138 d48 Srv: CPU affinity mask 0xff from 0xff.
8/19 8:17:51.138 d48 Srv: License data not found.
8/19 8:17:51.138 d48 Srv: *** LICENSE NOT FOUND! ***
8/19 8:17:51.138 d48 Srv: Please contact StarWind Software at <support@starwindsoftware.com> for more details.
8/19 8:17:51.138 d48 Srv: Config file: 'StarWindTapeRedirector.cfg'
8/19 8:17:51.169 d48 conf: Variable 'LogLevel' is set to '1'.
8/19 8:17:51.169 d48 conf: Variable 'LogMask' is set to '0x8fffffff'.
8/19 8:17:51.169 d48 conf: Variable 'UpdatePeriod' is set to '7'.
8/19 8:17:51.169 d48 conf: Variable 'UpdateHost' is set to 'www.starwindsoftware.com'.
8/19 8:17:51.169 d48 conf: Variable 'UpdatePage' is set to '/updatetracker/index.php'.
8/19 8:17:51.169 d48 conf: Variable 'UpdatePort' is set to '80'.
8/19 8:17:51.169 d48 conf: Variable 'UpdateCopyId' is set to ''.
8/19 8:17:51.169 d48 conf: Variable 'UpdateLastRequest' is set to '20100101'.
8/19 8:17:51.169 d48 conf: Variable 'Port' is set to '33268'.
8/19 8:17:51.169 d48 conf: Variable 'Interface' is set to '0.0.0.0'.
8/19 8:17:51.169 d48 conf: Variable 'CtlPort' is set to '33269'.
8/19 8:17:51.169 d48 conf: Variable 'BCastEnable' is set to 'yes'.
8/19 8:17:51.169 d48 conf: Variable 'BCastInterface' is set to '0.0.0.0'.
8/19 8:17:51.169 d48 conf: Variable 'BCastPort' is set to '33270'.
8/19 8:17:51.169 d48 conf: Variable 'Login' is set to 'root'.
8/19 8:17:51.169 d48 conf: Variable 'Password' is set to '##evVRsIJtRmAEEd2sCslZDg=='.
8/19 8:17:51.169 d48 conf: Variable 'MinBufferSize' is set to '65536'.
8/19 8:17:51.169 d48 conf: Variable 'AlignmentMask' is set to '0x0000'.
8/19 8:17:51.169 d48 conf: Variable 'MaxPendingRequests' is set to '64'.
8/19 8:17:51.169 d48 conf: Variable 'iScsiPingPeriod' is set to '0'.
8/19 8:17:51.169 d48 conf: Variable 'LocalizationDir' is set to 'Localizations'.
8/19 8:17:51.169 d48 conf: Variable 'DataBaseRoot' is set to '.\NotifyDB'.
8/19 8:17:51.169 d48 conf: Invalid variable 'DBRotationDays'.
8/19 8:17:51.169 d48 conf: Variable 'DBFileSizeDays' is set to '1'.
8/19 8:17:51.169 d48 conf: Variable 'PerformanceMonitorEnabled' is set to 'yes'.
8/19 8:17:51.169 d48 conf: Variable 'PerformanceRoot' is set to '.\PerformanceDB'.
8/19 8:17:51.169 d48 EventDB: wsRootDir = .\NotifyDB
8/19 8:17:51.169 d48 FileBrowser: Directory loaded: *|v|My Computer|*
8/19 8:17:51.169 d48 FileBrowser: Directory loaded: *|v|Image Files|img,dat
8/19 8:17:51.169 d48 FileBrowser: Directory loaded: *|cdmfv|Event Logs|txt,log
8/19 8:17:51.169 d48 conf: Failed to load 'DiskBridge.dll' (error 126).
8/19 8:17:51.169 d48 conf: Reaction of type 'eventlog' [0x0000003E, 0x0C] loaded successfully.
8/19 8:17:51.169 d48 conf: Variable 'DefaultAccessPolicy' is set to 'allow'.
8/19 8:17:51.169 d48 Srv: Update tracker options: UpdatePeriod = 7, UpdateLastRequest = 20100101, UpdateHost = http://www.starwindsoftware.com, UpdatePage = /updatetracker/index.php, UpdatePort = 80, Updat
CopyId =
8/19 8:17:51.169 d48 Srv: Refreshing device list (complete)...
8/19 8:17:51.169 d48 SPTI: '\\?\scsi#disk&ven_&prod_st31000528as#4&2f643da0&0&030000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}': ' ST31000528AS CC44': adapter 0, bus 3, target 0, LUN 0; maxTransferLeng
h 131072, alignmentMask 0x1
8/19 8:17:51.169 d48 PerformanceDB: CPerformanceCounter::WriteOperationalData called on uninitialized counter(DB entry: 0000000000000000, Record: 0000000000000000).
8/19 8:17:51.169 d48 PerformanceDB: CPerformanceCounter::Close exiting with error: WriteOperationalData failed.
8/19 8:17:51.169 d48 SPTI: '\\?\scsi#disk&ven_samsung&prod_hd103si#4&2f643da0&0&020000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}': ' SAMSUNG HD103SI 1AG01118': adapter 0, bus 2, target 0, LUN 0; maxTra
sferLength 131072, alignmentMask 0x1
8/19 8:17:51.169 d48 SPTI: '\\?\scsi#disk&ven_&prod_st2000dl001-9vt1#4&2f643da0&0&000000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}': ' ST2000DL001-9VT156 CC41': adapter 0, bus 0, target 0, LUN 0; maxTr
nsferLength 131072, alignmentMask 0x1
8/19 8:17:51.169 d48 SPTI: '\\?\scsi#disk&ven_wdc&prod_wd10eads-11m2b1#4&2f643da0&0&040000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}': ' WDC WD10EADS-11M2B1 01.00A01': adapter 0, bus 4, target 0, LUN 0
maxTransferLength 131072, alignmentMask 0x1
8/19 8:17:51.185 d48 SPTI: '\\?\usbstor#disk&ven_st2000dl&prod_001-9vt156&rev_#d40113ce594e130246000&0#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}': 'ST2000DL 001-9VT156 ': adapter 0, bus 0, target
0, LUN 0; maxTransferLength 65536, alignmentMask 0x0
8/19 8:17:51.185 d48 PerformanceDB: CPerformanceCounter::WriteOperationalData called on uninitialized counter(DB entry: 0000000000000000, Record: 0000000000000000).
8/19 8:17:51.185 d48 PerformanceDB: CPerformanceCounter::Close exiting with error: WriteOperationalData failed.
8/19 8:17:51.200 d48 SPTI: '\\?\scsi#cdrom&ven_hl-dt-st&prod_dvdram_gh22ns50#4&2f643da0&0&050000#{53f56308-b6bf-11d0-94f2-00a0c91efb8b}': 'HL-DT-ST DVDRAM GH22NS50 TN02': adapter 0, bus 5, target 0
LUN 0; maxTransferLength 131072, alignmentMask 0x1
8/19 8:17:51.200 d48 Srv: Found SPTI device '\\?\scsi#cdrom&ven_hl-dt-st&prod_dvdram_gh22ns50#4&2f643da0&0&050000#{53f56308-b6bf-11d0-94f2-00a0c91efb8b}': 'HL-DT-ST DVDRAM GH22NS50 TN02'
8/19 8:17:51.200 d48 SPTI: '\\?\scsi#sequential&ven_ibm&prod_ultrium-hh3#5&109d2a93&0&000600#{53f5630b-b6bf-11d0-94f2-00a0c91efb8b}': 'IBM ULTRIUM-HH3 73P9': adapter 1, bus 0, target 6, LU
8/19 8:17:51.200 d48 Srv: Found SPTI device '\\?\scsi#sequential&ven_ibm&prod_ultrium-hh3#5&109d2a93&0&000600#{53f5630b-b6bf-11d0-94f2-00a0c91efb8b}': 'IBM ULTRIUM-HH3 73P9'
8/19 8:17:51.200 9f8 conf: Waiting for Control connections at 0.0.0.0:33269 ...
8/19 8:17:51.200 c5c bc: Waiting for broadcast UDP packets at 0.0.0.0:33270...
8/19 8:17:51.216 d48 Srv: Waiting for iSCSI connections at 192.168.1.5:33268 ...
8/19 8:17:51.216 d48 Srv: Waiting for iSCSI connections at 127.0.0.1:33268 ...
8/19 8:17:51.216 c7c Srv: License data not found.
8/19 8:18:21.602 c7c Srv: StarWindService::UpdateTrackerThread: SW_CheckUpdate(host: 'www.starwindsoftware.com', page: '/updatetracker/index.php'') failed, error code 31(0x1f)!
8/19 8:21:01.753 9f8 conf: Accepted control connection from 127.0.0.1:49341.
8/19 8:21:01.753 cb4 conf: Control connection closed.
8/19 8:21:01.831 9f8 conf: Accepted control connection from 127.0.0.1:49342.
8/19 8:21:17.334 8b8 Srv: Unlimited number of client hosts allowed.
8/19 8:22:08.770 8b8 Srv: Refreshing device list (complete)...
8/19 8:22:08.770 8b8 SPTI: '\\?\scsi#disk&ven_&prod_st31000528as#4&2f643da0&0&030000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}': ' ST31000528AS CC44': adapter 0, bus 3, target 0, LUN 0; maxTransferLeng
8/19 8:22:08.770 8b8 Srv: Found SPTI device '\\?\scsi#disk&ven_&prod_st31000528as#4&2f643da0&0&030000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}': ' ST31000528AS CC44'
8/19 8:22:08.770 8b8 SPTI: '\\?\scsi#disk&ven_samsung&prod_hd103si#4&2f643da0&0&020000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}': ' SAMSUNG HD103SI 1AG01118': adapter 0, bus 2, target 0, LUN 0; maxTra
8/19 8:22:08.770 8b8 Srv: Found SPTI device '\\?\scsi#disk&ven_samsung&prod_hd103si#4&2f643da0&0&020000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}': ' SAMSUNG HD103SI 1AG01118'
8/19 8:22:08.770 8b8 SPTI: '\\?\scsi#disk&ven_&prod_st2000dl001-9vt1#4&2f643da0&0&000000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}': ' ST2000DL001-9VT156 CC41': adapter 0, bus 0, target 0, LUN 0; maxTr
8/19 8:22:08.770 8b8 Srv: Found SPTI device '\\?\scsi#disk&ven_&prod_st2000dl001-9vt1#4&2f643da0&0&000000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}': ' ST2000DL001-9VT156 CC41'
8/19 8:22:08.770 8b8 SPTI: '\\?\scsi#disk&ven_wdc&prod_wd10eads-11m2b1#4&2f643da0&0&040000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}': ' WDC WD10EADS-11M2B1 01.00A01': adapter 0, bus 4, target 0, LUN 0
8/19 8:22:08.770 8b8 Srv: Found SPTI device '\\?\scsi#disk&ven_wdc&prod_wd10eads-11m2b1#4&2f643da0&0&040000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}': ' WDC WD10EADS-11M2B1 01.00A01'
8/19 8:22:08.770 8b8 SPTI: '\\?\usbstor#disk&ven_st2000dl&prod_001-9vt156&rev_#d40113ce594e130246000&0#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}': 'ST2000DL 001-9VT156 ': adapter 0, bus 0, target
8/19 8:22:08.770 8b8 Srv: Found SPTI device '\\?\usbstor#disk&ven_st2000dl&prod_001-9vt156&rev_#d40113ce594e130246000&0#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}': 'ST2000DL 001-9VT156 '
8/19 8:22:08.770 8b8 PerformanceDB: CPerformanceCounter::WriteOperationalData called on uninitialized counter(DB entry: 0000000000000000, Record: 0000000000000000).
8/19 8:22:08.770 8b8 PerformanceDB: CPerformanceCounter::Close exiting with error: WriteOperationalData failed.
8/19 8:22:08.770 8b8 error: assertion failed: c:\_starwind\_v5\starwind\service\common\fn_common.cpp:28 (isEmpty())
8/19 8:22:08.786 8b8 SPTI: '\\?\scsi#cdrom&ven_hl-dt-st&prod_dvdram_gh22ns50#4&2f643da0&0&050000#{53f56308-b6bf-11d0-94f2-00a0c91efb8b}': 'HL-DT-ST DVDRAM GH22NS50 TN02': adapter 0, bus 5, target 0
8/19 8:22:08.786 8b8 Srv: Found SPTI device '\\?\scsi#cdrom&ven_hl-dt-st&prod_dvdram_gh22ns50#4&2f643da0&0&050000#{53f56308-b6bf-11d0-94f2-00a0c91efb8b}': 'HL-DT-ST DVDRAM GH22NS50 TN02'
8/19 8:22:08.786 8b8 PerformanceDB: CPerformanceCounter::WriteOperationalData called on uninitialized counter(DB entry: 0000000000000000, Record: 0000000000000000).
8/19 8:22:08.786 8b8 PerformanceDB: CPerformanceCounter::Close exiting with error: WriteOperationalData failed.
8/19 8:22:08.786 8b8 error: assertion failed: c:\_starwind\_v5\starwind\service\common\fn_common.cpp:28 (isEmpty())
8/19 8:22:08.786 8b8 SPTI: '\\?\scsi#sequential&ven_ibm&prod_ultrium-hh3#5&109d2a93&0&000600#{53f5630b-b6bf-11d0-94f2-00a0c91efb8b}': 'IBM ULTRIUM-HH3 73P9': adapter 1, bus 0, target 6, LU
8/19 8:22:08.786 8b8 Srv: Found SPTI device '\\?\scsi#sequential&ven_ibm&prod_ultrium-hh3#5&109d2a93&0&000600#{53f5630b-b6bf-11d0-94f2-00a0c91efb8b}': 'IBM ULTRIUM-HH3 73P9'
8/19 8:30:23.765 8b8 SPTI: '\\?\scsi#sequential&ven_ibm&prod_ultrium-hh3#5&109d2a93&0&000600#{53f5630b-b6bf-11d0-94f2-00a0c91efb8b}': share: 0 ('excl').
8/19 8:30:23.781 8b8 SPTI: '\\?\scsi#sequential&ven_ibm&prod_ultrium-hh3#5&109d2a93&0&000600#{53f5630b-b6bf-11d0-94f2-00a0c91efb8b}': 'IBM ULTRIUM-HH3 73P9': adapter 1, bus 0, target 6, LU
8/19 8:30:23.781 8b8 conf: Device [0x00000000002A27A0] '\\?\scsi#sequential&ven_ibm&prod_ultrium-hh3#5&109d2a93&0&000600#{53f5630b-b6bf-11d0-94f2-00a0c91efb8b}' has been created.
8/19 8:30:23.827 8b8 Srv: Creating target 'iqn.2008-08.com.starwindsoftware:server-tape', device list '\\?\scsi#sequential&ven_ibm&prod_ultrium-hh3#5&109d2a93&0&000600#{53f5630b-b6bf-11d0-94f2-00a0c
1efb8b}'...
8/19 8:30:23.827 8b8 PerformanceDB: CFilePerformanceDB_Win::CFileDBEntry::Open exiting with error: CreateFileW(.\PerformanceDB\PerformanceData_\\?\scsi#sequential&ven_ibm&prod_ultrium-hh3#5&109d2a93
0&000600#{53f5630b-b6bf-11d0-94f2-00a0c91efb8b}.swpf) failed with error 3.
8/19 8:30:23.827 8b8 PerformanceDB: CFilePerformanceDB_Win::CreateDBEntry exiting with error: CFileDBEntry::Open(.\PerformanceDB) failed.
8/19 8:30:23.827 8b8 PerformanceDB: CFilePerformanceDB_Win::GetDBEntry failed to create DB entry. Return value is NULL.
8/19 8:30:23.827 8b8 PerformanceDB: Counter initialization failed: DB entry is NULL.
8/19 8:30:23.827 8b8 PerformanceDB: *ERROR* Device \\?\scsi#sequential&ven_ibm&prod_ultrium-hh3#5&109d2a93&0&000600#{53f5630b-b6bf-11d0-94f2-00a0c91efb8b} : Unable to attach IO Performance Counter t
target(iqn.2008-08.com.starwindsoftware:server-tape) composite counter.
8/19 8:30:23.827 8b8 Tgt: : parameter 'readonly', value 'no'.
8/19 8:30:23.827 8b8 Tgt: : share 0 ('').
8/19 8:30:23.827 8b8 Tgt: : parameter '#_TargetName_#', value 'iqn.2008-08.com.starwindsoftware:server-tape'.
8/19 8:30:23.827 8b8 Tgt: iqn.2008-08.com.starwindsoftware:server-tape: device \\?\scsi#sequential&ven_ibm&prod_ultrium-hh3#5&109d2a93&0&000600#{53f5630b-b6bf-11d0-94f2-00a0c91efb8b}: new LUN 0 mapp
d to target LUN 0.
8/19 8:30:23.827 8b8 Tgt: iqn.2008-08.com.starwindsoftware:server-tape: attached device \\?\scsi#sequential&ven_ibm&prod_ultrium-hh3#5&109d2a93&0&000600#{53f5630b-b6bf-11d0-94f2-00a0c91efb8b} (found
1 LUNs).
8/19 8:30:23.827 8b8 conf: Target [0x0000000000259D60] 'iqn.2008-08.com.starwindsoftware:server-tape' has been created, 1 devices attached.
8/19 8:35:18.556 9f8 conf: Accepted control connection from 192.168.1.5:49350.
8/19 8:35:18.556 4b8 conf: Control connection closed.
8/19 8:35:59.192 8b8 Srv: Updating target 0000000000259D60 'iqn.2008-08.com.starwindsoftware:server-tape', device list ''...
8/19 8:35:59.192 8b8 Tgt: iqn.2008-08.com.starwindsoftware:server-tape: device '\\?\scsi#sequential&ven_ibm&prod_ultrium-hh3#5&109d2a93&0&000600#{53f5630b-b6bf-11d0-94f2-00a0c91efb8b}' is detached.
8/19 8:35:59.192 8b8 conf: Target [0x0000000000259D60] 'iqn.2008-08.com.starwindsoftware:server-tape' has been updated, 0 devices attached.
8/19 8:35:59.239 8b8 Srv: Removing device '\\?\scsi#sequential&ven_ibm&prod_ultrium-hh3#5&109d2a93&0&000600#{53f5630b-b6bf-11d0-94f2-00a0c91efb8b}'...
8/19 8:35:59.239 8b8 PerformanceDB: CPerformanceCounter::WriteOperationalData called on uninitialized counter(DB entry: 0000000000000000, Record: 0000000000000000).
8/19 8:35:59.239 8b8 PerformanceDB: CPerformanceCounter::Close exiting with error: WriteOperationalData failed.
8/19 8:35:59.239 8b8 Srv: Device '\\?\scsi#sequential&ven_ibm&prod_ultrium-hh3#5&109d2a93&0&000600#{53f5630b-b6bf-11d0-94f2-00a0c91efb8b}' is closed.
8/19 8:35:59.239 8b8 Srv: Device '\\?\scsi#sequential&ven_ibm&prod_ultrium-hh3#5&109d2a93&0&000600#{53f5630b-b6bf-11d0-94f2-00a0c91efb8b}' has been removed.
8/19 8:35:59.255 8b8 Srv: Removing target 'iqn.2008-08.com.starwindsoftware:server-tape'...
8/19 8:35:59.255 8b8 Srv: Target 'iqn.2008-08.com.starwindsoftware:server-tape' has been removed.
8/19 8:35:59.255 8b8 error: assertion failed: c:\_starwind\_v5\starwind\service\common\fn_common.cpp:28 (isEmpty())
8/19 8:35:59.286 8b8 Srv: Refreshing device list (complete)...
8/19 8:35:59.286 8b8 PerformanceDB: CPerformanceCounter::WriteOperationalData called on uninitialized counter(DB entry: 0000000000000000, Record: 0000000000000000).
8/19 8:35:59.286 8b8 PerformanceDB: CPerformanceCounter::Close exiting with error: WriteOperationalData failed.
8/19 8:35:59.286 8b8 error: assertion failed: c:\_starwind\_v5\starwind\service\common\fn_common.cpp:28 (isEmpty())
8/19 8:35:59.286 8b8 SPTI: '\\?\scsi#disk&ven_&prod_st31000528as#4&2f643da0&0&030000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}': ' ST31000528AS CC44': adapter 0, bus 3, target 0, LUN 0; maxTransferLeng
8/19 8:35:59.286 8b8 Srv: Found SPTI device '\\?\scsi#disk&ven_&prod_st31000528as#4&2f643da0&0&030000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}': ' ST31000528AS CC44'
8/19 8:35:59.286 8b8 SPTI: '\\?\scsi#disk&ven_samsung&prod_hd103si#4&2f643da0&0&020000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}': ' SAMSUNG HD103SI 1AG01118': adapter 0, bus 2, target 0, LUN 0; maxTra
8/19 8:35:59.286 8b8 Srv: Found SPTI device '\\?\scsi#disk&ven_samsung&prod_hd103si#4&2f643da0&0&020000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}': ' SAMSUNG HD103SI 1AG01118'
8/19 8:35:59.286 8b8 SPTI: '\\?\scsi#disk&ven_&prod_st2000dl001-9vt1#4&2f643da0&0&000000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}': ' ST2000DL001-9VT156 CC41': adapter 0, bus 0, target 0, LUN 0; maxTr
8/19 8:35:59.286 8b8 Srv: Found SPTI device '\\?\scsi#disk&ven_&prod_st2000dl001-9vt1#4&2f643da0&0&000000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}': ' ST2000DL001-9VT156 CC41'
8/19 8:35:59.286 8b8 SPTI: '\\?\scsi#disk&ven_wdc&prod_wd10eads-11m2b1#4&2f643da0&0&040000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}': ' WDC WD10EADS-11M2B1 01.00A01': adapter 0, bus 4, target 0, LUN 0
8/19 8:35:59.286 8b8 Srv: Found SPTI device '\\?\scsi#disk&ven_wdc&prod_wd10eads-11m2b1#4&2f643da0&0&040000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}': ' WDC WD10EADS-11M2B1 01.00A01'
8/19 8:35:59.286 8b8 SPTI: '\\?\usbstor#disk&ven_st2000dl&prod_001-9vt156&rev_#d40113ce594e130246000&0#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}': 'ST2000DL 001-9VT156 ': adapter 0, bus 0, target
8/19 8:35:59.286 8b8 Srv: Found SPTI device '\\?\usbstor#disk&ven_st2000dl&prod_001-9vt156&rev_#d40113ce594e130246000&0#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}': 'ST2000DL 001-9VT156 '
8/19 8:35:59.301 8b8 SPTI: '\\?\scsi#cdrom&ven_hl-dt-st&prod_dvdram_gh22ns50#4&2f643da0&0&050000#{53f56308-b6bf-11d0-94f2-00a0c91efb8b}': 'HL-DT-ST DVDRAM GH22NS50 TN02': adapter 0, bus 5, target 0
8/19 8:35:59.301 8b8 Srv: Found SPTI device '\\?\scsi#cdrom&ven_hl-dt-st&prod_dvdram_gh22ns50#4&2f643da0&0&050000#{53f56308-b6bf-11d0-94f2-00a0c91efb8b}': 'HL-DT-ST DVDRAM GH22NS50 TN02'
8/19 8:35:59.301 8b8 SPTI: '\\?\scsi#sequential&ven_ibm&prod_ultrium-hh3#5&109d2a93&0&000600#{53f5630b-b6bf-11d0-94f2-00a0c91efb8b}': 'IBM ULTRIUM-HH3 73P9': adapter 1, bus 0, target 6, LU
8/19 8:35:59.301 8b8 Srv: Found SPTI device '\\?\scsi#sequential&ven_ibm&prod_ultrium-hh3#5&109d2a93&0&000600#{53f5630b-b6bf-11d0-94f2-00a0c91efb8b}': 'IBM ULTRIUM-HH3 73P9'
8/19 8:36:46.258 9f8 conf: Accepted control connection from 192.168.1.5:49351.
8/19 8:37:25.274 fac Srv: Refreshing device list (complete)...
8/19 8:37:25.274 fac PerformanceDB: CPerformanceCounter::WriteOperationalData called on uninitialized counter(DB entry: 0000000000000000, Record: 0000000000000000).
8/19 8:37:25.274 fac PerformanceDB: CPerformanceCounter::Close exiting with error: WriteOperationalData failed.
8/19 8:37:25.274 fac error: assertion failed: c:\_starwind\_v5\starwind\service\common\fn_common.cpp:28 (isEmpty())
8/19 8:37:25.274 fac SPTI: '\\?\scsi#disk&ven_&prod_st31000528as#4&2f643da0&0&030000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}': ' ST31000528AS CC44': adapter 0, bus 3, target 0, LUN 0; maxTransferLeng
8/19 8:37:25.274 fac Srv: Found SPTI device '\\?\scsi#disk&ven_&prod_st31000528as#4&2f643da0&0&030000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}': ' ST31000528AS CC44'
8/19 8:37:25.274 fac SPTI: '\\?\scsi#disk&ven_samsung&prod_hd103si#4&2f643da0&0&020000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}': ' SAMSUNG HD103SI 1AG01118': adapter 0, bus 2, target 0, LUN 0; maxTra
8/19 8:37:25.274 fac Srv: Found SPTI device '\\?\scsi#disk&ven_samsung&prod_hd103si#4&2f643da0&0&020000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}': ' SAMSUNG HD103SI 1AG01118'
8/19 8:37:25.274 fac SPTI: '\\?\scsi#disk&ven_&prod_st2000dl001-9vt1#4&2f643da0&0&000000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}': ' ST2000DL001-9VT156 CC41': adapter 0, bus 0, target 0, LUN 0; maxTr
8/19 8:37:25.274 fac Srv: Found SPTI device '\\?\scsi#disk&ven_&prod_st2000dl001-9vt1#4&2f643da0&0&000000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}': ' ST2000DL001-9VT156 CC41'
8/19 8:37:25.274 fac SPTI: '\\?\scsi#disk&ven_wdc&prod_wd10eads-11m2b1#4&2f643da0&0&040000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}': ' WDC WD10EADS-11M2B1 01.00A01': adapter 0, bus 4, target 0, LUN 0
8/19 8:37:25.274 fac Srv: Found SPTI device '\\?\scsi#disk&ven_wdc&prod_wd10eads-11m2b1#4&2f643da0&0&040000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}': ' WDC WD10EADS-11M2B1 01.00A01'
8/19 8:37:25.274 fac SPTI: '\\?\usbstor#disk&ven_st2000dl&prod_001-9vt156&rev_#d40113ce594e130246000&0#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}': 'ST2000DL 001-9VT156 ': adapter 0, bus 0, target
8/19 8:37:25.290 fac Srv: Found SPTI device '\\?\usbstor#disk&ven_st2000dl&prod_001-9vt156&rev_#d40113ce594e130246000&0#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}': 'ST2000DL 001-9VT156 '
8/19 8:37:25.290 fac PerformanceDB: CPerformanceCounter::WriteOperationalData called on uninitialized counter(DB entry: 0000000000000000, Record: 0000000000000000).
8/19 8:37:25.290 fac PerformanceDB: CPerformanceCounter::Close exiting with error: WriteOperationalData failed.
8/19 8:37:25.290 fac error: assertion failed: c:\_starwind\_v5\starwind\service\common\fn_common.cpp:28 (isEmpty())
8/19 8:37:25.290 fac SPTI: '\\?\scsi#cdrom&ven_hl-dt-st&prod_dvdram_gh22ns50#4&2f643da0&0&050000#{53f56308-b6bf-11d0-94f2-00a0c91efb8b}': 'HL-DT-ST DVDRAM GH22NS50 TN02': adapter 0, bus 5, target 0
8/19 8:37:25.290 fac Srv: Found SPTI device '\\?\scsi#cdrom&ven_hl-dt-st&prod_dvdram_gh22ns50#4&2f643da0&0&050000#{53f56308-b6bf-11d0-94f2-00a0c91efb8b}': 'HL-DT-ST DVDRAM GH22NS50 TN02'
8/19 8:37:25.307 fac SPTI: '\\?\scsi#sequential&ven_ibm&prod_ultrium-hh3#5&109d2a93&0&000600#{53f5630b-b6bf-11d0-94f2-00a0c91efb8b}': 'IBM ULTRIUM-HH3 73P9': adapter 1, bus 0, target 6, LU
8/19 8:37:25.307 fac Srv: Found SPTI device '\\?\scsi#sequential&ven_ibm&prod_ultrium-hh3#5&109d2a93&0&000600#{53f5630b-b6bf-11d0-94f2-00a0c91efb8b}': 'IBM ULTRIUM-HH3 73P9'
8/19 8:37:42.629 fac SPTI: '\\?\scsi#sequential&ven_ibm&prod_ultrium-hh3#5&109d2a93&0&000600#{53f5630b-b6bf-11d0-94f2-00a0c91efb8b}': share: 0 ('excl').
8/19 8:37:42.645 fac SPTI: '\\?\scsi#sequential&ven_ibm&prod_ultrium-hh3#5&109d2a93&0&000600#{53f5630b-b6bf-11d0-94f2-00a0c91efb8b}': 'IBM ULTRIUM-HH3 73P9': adapter 1, bus 0, target 6, LU
8/19 8:37:42.645 fac conf: Device [0x00000000002FE8D0] '\\?\scsi#sequential&ven_ibm&prod_ultrium-hh3#5&109d2a93&0&000600#{53f5630b-b6bf-11d0-94f2-00a0c91efb8b}' has been created.
8/19 8:37:42.692 fac Srv: Creating target 'iqn.2008-08.com.starwindsoftware:192.168.1.5-tape', device list '\\?\scsi#sequential&ven_ibm&prod_ultrium-hh3#5&109d2a93&0&000600#{53f5630b-b6bf-11d0-94f2-
0a0c91efb8b}'...
8/19 8:37:42.692 fac PerformanceDB: CFilePerformanceDB_Win::CFileDBEntry::Open exiting with error: CreateFileW(.\PerformanceDB\PerformanceData_\\?\scsi#sequential&ven_ibm&prod_ultrium-hh3#5&109d2a93
8/19 8:37:42.692 fac PerformanceDB: CFilePerformanceDB_Win::CreateDBEntry exiting with error: CFileDBEntry::Open(.\PerformanceDB) failed.
8/19 8:37:42.692 fac PerformanceDB: CFilePerformanceDB_Win::GetDBEntry failed to create DB entry. Return value is NULL.
8/19 8:37:42.692 fac PerformanceDB: Counter initialization failed: DB entry is NULL.
8/19 8:37:42.692 fac PerformanceDB: *ERROR* Device \\?\scsi#sequential&ven_ibm&prod_ultrium-hh3#5&109d2a93&0&000600#{53f5630b-b6bf-11d0-94f2-00a0c91efb8b} : Unable to attach IO Performance Counter t
target(iqn.2008-08.com.starwindsoftware:192.168.1.5-tape) composite counter.
8/19 8:37:42.692 fac Tgt: : parameter 'readonly', value 'no'.
8/19 8:37:42.692 fac Tgt: : share 0 ('').
8/19 8:37:42.692 fac Tgt: : parameter '#_TargetName_#', value 'iqn.2008-08.com.starwindsoftware:192.168.1.5-tape'.
8/19 8:37:42.692 fac Tgt: iqn.2008-08.com.starwindsoftware:192.168.1.5-tape: device \\?\scsi#sequential&ven_ibm&prod_ultrium-hh3#5&109d2a93&0&000600#{53f5630b-b6bf-11d0-94f2-00a0c91efb8b}: new LUN 0
mapped to target LUN 0.
8/19 8:37:42.692 fac Tgt: iqn.2008-08.com.starwindsoftware:192.168.1.5-tape: attached device \\?\scsi#sequential&ven_ibm&prod_ultrium-hh3#5&109d2a93&0&000600#{53f5630b-b6bf-11d0-94f2-00a0c91efb8b} (
ound 1 LUNs).
8/19 8:37:42.692 fac conf: Target [0x00000000002F6FB0] 'iqn.2008-08.com.starwindsoftware:192.168.1.5-tape' has been created, 1 devices attached.
Mon Aug 19, 2013 9:05 pm
We've asked here:
http://www.starwindsoftware.com/forums/ ... -t740.html
Not to embedd the log to the forum messages. They (logs) get truncated. Please zip the log and send to support@starwindsoftware.com with an URL to this thread. Thanks!
daku97
Tue Aug 20, 2013 3:36 pm
Anatoly, thank you for your email response, i have installed the additional software as requested but can still not connect to the tape drive. can we scheduled a webex to review my settings?
Tue Aug 20, 2013 4:25 pm
You're using the wrong ports to connect to. StarWind tape redirector does not use default port 3260 for iSCSI (we're going to change this and keep unified code). So just make sure you connect to the port tape redirector uses - 33268 in your case.
daku97
Tue Aug 20, 2013 5:30 pm
Using the post 33268 allowed me to connect. How would I have known if you did not specify? I see nothing referring to this port in the Starwind console.
Tue Aug 20, 2013 6:11 pm
That's a big drawback and we'll fix this making unified installer and product. Sorry for confusion!
daku97 wrote:Using the post 33268 allowed me to connect. How would I have known if you did not specify? I see nothing referring to this port in the Starwind console.
daku97
Tue Aug 20, 2013 6:50 pm
Great, thanks again for the help!!!
Tue Aug 20, 2013 9:38 pm
You're welcomed :)
