Hi Guys,
I am having problems trying to install the Tape Redirector on Server 2012 Core. I didn't want to necro an existing thread but this is basically my problem:
http://www.starwindsoftware.com/forums/ ... tml#p16539
We are using a Windows Server 2012 installed with Core only.
I have then added the following features to get a very minimal GUI:
Install-WindowsFeature Hyper-V
Install-WindowsFeature Hyper-V-Powershell
Install-WindowsFeature Server-Gui-Mgmt-Infra
Install-WindowsFeature RSAT-Hyper-V-Tools
NOTE: It would be great if in the future the Tape Redirector GUI could work with this build as there are a number of other consoles that work in this environment but it does not add a full GUI bloat.
Now from the previous thread it stated that the Management Console option was the reason I received the error but unchecking that and just trying to install the service results in the same "Not Implemented" error.
Am I missing something here? Or is this still not fixed?
