Starwind CDP Edition and Veeam B&R
greenpower
Mon Jul 15, 2013 8:31 pm
does starwind CDP edition supports VSS Hardware provider which is neccessary for Veeams B&R off-host backup proxy feature? (in hyper-v cluster environment)
The veeams off-host backup proxy feature bypasses the hyper-v node on which the VM resides and connects directly to the storage to take the cpu load of the hyper-v node to the off-host backup proxy while backup.
Another benefit is the the VM which is beeing backuped is in redirected i/o mode only for the time of an VSS snapshot. If not using the off-host backup proxy the VM is in redirected mode for the whole time
of the backup and the backup cpu load remains on the hyper-v node on which the VM resides.
thank you!
Wed Jul 17, 2013 12:48 pm
Yes, it is supported. You can find the download link to our Software and Hardware VSS providers on your customer page that you can find by using the link below:
http://www.starwindsoftware.com/customer-page
I hope it helped
