PowerShell management library - Problem on Install
jwillis84
Tue Jun 25, 2013 3:32 pm
StarWind
Version 6.0.5569
Upon attempting to perform a Full install on Windows Server 2012 Standard, the following Error message occurs.
[see attachment for a screen capture of the Error Message]
Revising the install to exclude the [ PowerShell management library for StarWind Services ] allows the installation to proceed.
[see attachement for a screen capture of the Select Components that were unchecked]
Could you provide any advice to allow the component to install?
Are there any prerequsites for Windows Server 2012 Standard that allow this to be installed?
Thank you
Thu Jun 27, 2013 3:27 pm
We have just updated the build that fixes the issue that you`ve described. Please u[date your SAN software and try it out.
