SPTI Problem,Cannot Connect
mahuan1688
Mon Jun 24, 2013 4:15 am
The free version I am using 6.0.5569, 30 days from the date of limit, while I build SPTI equipment are successful, but when the access to this device does not suggest how to resolve this issue, ah, I have attached 2 pictures.Disk bridge has The same problem. :D,thanks!
Max (staff)
Mon Jun 24, 2013 10:17 am
Hello Mahuan1688,
Could you please tell me if you get the same error message when connecting using Microsoft iSCSI initiator.
Also, what is the device you're trying to export via iSCSI?
Max Kolomyeytsev
mahuan1688
Tue Jun 25, 2013 1:45 am
when connect use microsoft Microsoft iSCSI initiator,The following error, I attach a picture.
Recorder(dvd-rw) and publish the entire hard disk(disk bridge)
mahuan1688
Tue Jun 25, 2013 6:08 am
I think, these 2 problems have been solved, thank you!
Tue Jun 25, 2013 10:15 am
Thank you for the heads up!
May I wonder what was the reason of the issue and how did you managed to solve it?
