MPIO on ESX
xadox
Mon May 06, 2013 1:36 pm
I have installed StarWind Free on a Windows Server 2008 x64. the Server has two NIC's:
  • 10.0.0.1
  • 10.0.0.2
These are reserved for the iSCSI Network.
The ESX Server also has two nics with separated vswitches:
  • 10.0.0.11
  • 10.0.0.12
After adding both IP's to the ESX Software initiator it will only add one of the paths?
I think there sholud be both paths listed in the esx overview.
Mon May 06, 2013 5:41 pm
Configure dual networks. Something like 192.168.0.xxx and 192.168.1.yyy should work.
xadox
Tue May 07, 2013 5:12 am
Ok now I have
  • 10.0.173.1
  • 10.0.174.1
but this still not works for me.
I have also done this:
...uncomment the <iScsiDiscoveryListInterfaces value=”1″/> line in the starwind.cfg file.
xadox
Tue May 14, 2013 10:09 am
Any chance of a clue?
Wed May 15, 2013 2:53 pm
Do you see both conenctions listed under the iSCSI Sessions tab in SW Mgmt console?
xadox
Thu May 16, 2013 6:09 am
The ESX Server is only listed ones.
Thu May 16, 2013 8:32 am
But you see both connections there? Can you drop us the corresponding screenshot?
xadox
Thu May 16, 2013 11:17 am
No.
Max (staff)
Thu May 16, 2013 11:50 am
There is a small thing we may be missing here. Did you enable the "allow multiple concurrent iSCSI connections" checkbox when creating the target?
This should be visible in the SW management console
If clustering is off - delete the target, choose "detach device" option, then create a new target with clustering enabled, right click over the device and attach it to the new target. After that do a full rescan on the ESX hosts.
Max Kolomyeytsev
xadox
Thu May 16, 2013 11:55 am
Yes.
Mon May 20, 2013 10:36 am
Could you provide with with the iSCSI Sessions tab screenshot from the issued target (I`ve attached an example)?
xadox
Tue May 21, 2013 5:36 am
Listed are our two esx servers and one windows server 2008 mashine.
Thu May 23, 2013 10:41 am
AFAIR ESX has Fixed NLB policy, which is using one path as active only. Could you switch it to Round Robin and see if it works?
xadox
Thu May 23, 2013 11:22 am
Hmm... I am already using round robin.
Max (staff)
Tue May 28, 2013 8:11 am
Xadox, is there any chance I could hop on a remote session to your environment?
I'm usually available from 9 to 6 CET.
Max Kolomyeytsev
