Deleting Dedupe device
Qtrop
Mon Apr 08, 2013 2:59 am
I noticed that when I delete a dedupe device the corresponding disk files are not deleted
(dddb, spdata and spmetadata)
Any reason these arent deleted by the remove devive command and any reason I cant
delete these(I really need the 3TB that it consumed)
thanks
MIke
jeddyatcc
Mon Apr 08, 2013 12:38 pm
To my knowledge, deleting a device in Starwind does not remove the underlying files. Some procedures, like changing the cache sizes, require that you delete the device and recreate it using the same disk image. When I delete devices and targets, if I want to remove them for good, I just delete the img files as well.
Wed Apr 10, 2013 10:11 am
I can confirm that. This behavior is caused by the fact that those files can be used after the device was removed for some procedures or operations.
