Delete all snapshots - files still left
robnicholson
Tue Mar 26, 2013 4:42 pm
One of our virtual disks had some snapshots - we're not exactly sure where they came from. Happens to be the C: drive from a XenServer VM so I exported the VM from XenServer "just in case". I then opened up the Snapshot manager and clicked Delete All. This removed all the snapshots from the list but the disk is still full of multiple ibvd files. Is the deletion of these some background task and I just need to be patient? Screenshot attached.
Regards, Rob.
Thu Mar 28, 2013 4:42 pm
Hi!
I`ll recommend you to take a closer look at the following topics:
http://www.starwindsoftware.com/forums/ ... t2599.html
http://www.starwindsoftware.com/forums/ ... t2694.html
http://www.starwindsoftware.com/forums/ ... t1466.html
I hope they will help you to solve your issue.
robnicholson
Thu Mar 28, 2013 4:58 pm
Hiya - none of those links work.
Regards, Rob.
Mon Apr 01, 2013 10:07 am
Thanks for letting us know. Probably the`ve been broken during submitting the post.
I`ve just fixed them - try them out please.
