Migrating the mount points to another server
diwakarar
Mon Jan 14, 2013 6:49 am
I have implemented starwind in my env to create cluster lun's.Basically I have installed the software on a Physical box with a lot of free space of around 1.5TB. I have created luns and mapped them to different Clustered applications through iSCSI initiator.Now the server is out of space to extend the size of the luns further.Now I m planning to move the mount points to some other physical server with more HDD space. Basically we are using the starwind with Hyper-v machines.
So, someone can help to let me know, whether it is possible to move the mount points to some other server or not ?
If yes just briefly how the process will be.'
Even I m planning to install starwind on different server and from there mount the pre-existing .img files.
Mon Jan 14, 2013 8:56 pm
Absolutely. You just move .img files to the new data store and re-install StarWind there exporting existing .imgs as iSCSI targets. That's pretty much all.
diwakarar
Tue Jan 15, 2013 8:16 am
Thank you for your immediate reply, I will give it a try and get back to you if I need any further info.
Diwakar.
Wed Jan 16, 2013 11:26 am
Yes, please keep us updated about your progress. Thank you!
diwakarar wrote:Hi,
Diwakar.
