empty disk bridge list
laki78
Fri Jan 04, 2013 5:09 pm
I'm using Starwind 6.0.5189 and I'm trying to add a new Device->Raw Device->Disk Bridge to the target on a virtual machine Win 2008 R2 on ESXi 5 host.
VM disks are standard Vmware SCSI disks connected to standard LSI SAS controller. They are visible in Windows Disk Management Console.
When running add new device to the target wizard I'm choosing Raw Device->Disk Bridge, but the disk list is empty - no disk available for adding.
When I add to the VM a IDE disk, I can see and add is as Disk Bridge.
Could you tell me where can be the problem ? SCSI disks are not supported ??
thanks for help
Laki78
Fri Jan 04, 2013 5:12 pm
Somebody is keeping handle opened on a raw device (grab StarWing log to see it). Also it's not recommended to raw map devices as it's the WORST performance method. Stick with image files.
laki78
Fri Jan 04, 2013 5:24 pm
I don't understand what you mean.
Here is what I can see in the log file:
1/4 18:12:08.059 364 Srv: Refreshing device list (complete)...
1/4 18:12:08.059 364 SPTI: '\\?\scsi#disk&ven_vmware&prod_virtual_disk#5&22be343f&0&000000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}': 'VMware Virtual disk 1.0 ': adapter 2, bus 0, target 0, LUN 0; maxTransferLength 16777215, alignmentMask 0x0
1/4 18:12:08.059 364 SCSI: Capacity data too short (0). The device \\?\scsi#disk&ven_vmware&prod_virtual_disk#5&22be343f&0&000000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b} is not allowed.
1/4 18:12:08.059 364 PerformanceDB: CPerformanceCounter::WriteOperationalData called on uninitialized counter(DB entry: 0000000000000000, Record: 0000000000000000).
1/4 18:12:08.059 364 PerformanceDB: CPerformanceCounter::Close exiting with error: WriteOperationalData failed.
1/4 18:12:08.059 364 SPTI: '\\?\scsi#disk&ven_vmware&prod_virtual_disk#5&22be343f&0&000100#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}': 'VMware Virtual disk 1.0 ': adapter 2, bus 0, target 1, LUN 0; maxTransferLength 16777215, alignmentMask 0x0
1/4 18:12:08.059 364 SCSI: Capacity data too short (0). The device \\?\scsi#disk&ven_vmware&prod_virtual_disk#5&22be343f&0&000100#{53f56307-b6bf-11d0-94f2-00a0c91efb8b} is not allowed.
1/4 18:12:08.059 364 SPTI: '\\?\scsi#disk&ven_vmware&prod_virtual_disk#5&22be343f&0&000200#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}': 'VMware Virtual disk 1.0 ': adapter 2, bus 0, target 2, LUN 0; maxTransferLength 16777215, alignmentMask 0x0
1/4 18:12:08.059 364 SCSI: Capacity data too short (0). The device \\?\scsi#disk&ven_vmware&prod_virtual_disk#5&22be343f&0&000200#{53f56307-b6bf-11d0-94f2-00a0c91efb8b} is not allowed.
1/4 18:12:08.059 364 SPTI: '\\?\scsi#disk&ven_vmware&prod_virtual_disk#5&22be343f&0&000300#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}': 'VMware Virtual disk 1.0 ': adapter 2, bus 0, target 3, LUN 0; maxTransferLength 16777215, alignmentMask 0x0
1/4 18:12:08.059 364 SCSI: Capacity data too short (0). The device \\?\scsi#disk&ven_vmware&prod_virtual_disk#5&22be343f&0&000300#{53f56307-b6bf-11d0-94f2-00a0c91efb8b} is not allowed.
1/4 18:12:08.059 364 SPTI: '\\?\scsi#disk&ven_vmware&prod_virtual_disk#5&22be343f&0&000400#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}': 'VMware Virtual disk 1.0 ': adapter 2, bus 0, target 4, LUN 0; maxTransferLength 16777215, alignmentMask 0x0
1/4 18:12:08.059 364 SCSI: Capacity data too short (0). The device \\?\scsi#disk&ven_vmware&prod_virtual_disk#5&22be343f&0&000400#{53f56307-b6bf-11d0-94f2-00a0c91efb8b} is not allowed.
1/4 18:12:08.059 364 SPTI: '\\?\scsi#disk&ven_vmware&prod_virtual_disk#5&22be343f&0&000500#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}': 'VMware Virtual disk 1.0 ': adapter 2, bus 0, target 5, LUN 0; maxTransferLength 16777215, alignmentMask 0x0
1/4 18:12:08.059 364 SCSI: Capacity data too short (0). The device \\?\scsi#disk&ven_vmware&prod_virtual_disk#5&22be343f&0&000500#{53f56307-b6bf-11d0-94f2-00a0c91efb8b} is not allowed.
1/4 18:12:08.059 364 SPTI: '\\?\scsi#disk&ven_vmware&prod_virtual_disk#5&22be343f&0&000600#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}': 'VMware Virtual disk 1.0 ': adapter 2, bus 0, target 6, LUN 0; maxTransferLength 16777215, alignmentMask 0x0
1/4 18:12:08.059 364 SCSI: Capacity data too short (0). The device \\?\scsi#disk&ven_vmware&prod_virtual_disk#5&22be343f&0&000600#{53f56307-b6bf-11d0-94f2-00a0c91efb8b} is not allowed.
1/4 18:12:08.059 364 SPTI: '\\?\scsi#disk&ven_vmware&prod_virtual_disk#5&22be343f&0&000800#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}': 'VMware Virtual disk 1.0 ': adapter 2, bus 0, target 8, LUN 0; maxTransferLength 16777215, alignmentMask 0x0
1/4 18:12:08.059 364 SCSI: Capacity data too short (0). The device \\?\scsi#disk&ven_vmware&prod_virtual_disk#5&22be343f&0&000800#{53f56307-b6bf-11d0-94f2-00a0c91efb8b} is not allowed.
1/4 18:12:08.059 364 SPTI: '\\?\scsi#disk&ven_vmware&prod_virtual_disk#5&22be343f&0&000900#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}': 'VMware Virtual disk 1.0 ': adapter 2, bus 0, target 9, LUN 0; maxTransferLength 16777215, alignmentMask 0x0
1/4 18:12:08.074 364 SCSI: Capacity data too short (0). The device \\?\scsi#disk&ven_vmware&prod_virtual_disk#5&22be343f&0&000900#{53f56307-b6bf-11d0-94f2-00a0c91efb8b} is not allowed.
1/4 18:12:08.074 364 PerformanceDB: CPerformanceCounter::WriteOperationalData called on uninitialized counter(DB entry: 0000000000000000, Record: 0000000000000000).
1/4 18:12:08.074 364 PerformanceDB: CPerformanceCounter::Close exiting with error: WriteOperationalData failed.
1/4 18:12:08.074 364 SPTI: '\\?\scsi#disk&ven_vmware&prod_virtual_disk#5&22be343f&0&000a00#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}': 'VMware Virtual disk 1.0 ': adapter 2, bus 0, target 10, LUN 0; maxTransferLength 16777215, alignmentMask 0x0
1/4 18:12:08.074 364 SCSI: Capacity data too short (0). The device \\?\scsi#disk&ven_vmware&prod_virtual_disk#5&22be343f&0&000a00#{53f56307-b6bf-11d0-94f2-00a0c91efb8b} is not allowed.
1/4 18:12:08.074 364 SPTI: '\\?\scsi#disk&ven_vmware&prod_virtual_disk#5&22be343f&0&000b00#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}': 'VMware Virtual disk 1.0 ': adapter 2, bus 0, target 11, LUN 0; maxTransferLength 16777215, alignmentMask 0x0
1/4 18:12:08.074 364 SCSI: Capacity data too short (0). The device \\?\scsi#disk&ven_vmware&prod_virtual_disk#5&22be343f&0&000b00#{53f56307-b6bf-11d0-94f2-00a0c91efb8b} is not allowed.
1/4 18:12:08.074 364 SPTI: '\\?\scsi#disk&ven_vmware&prod_virtual_disk#5&2fc68f79&0&000000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}': 'VMware Virtual disk 1.0 ': adapter 3, bus 0, target 0, LUN 0; maxTransferLength 16777215, alignmentMask 0x0
1/4 18:12:08.074 364 SCSI: Capacity data too short (0). The device \\?\scsi#disk&ven_vmware&prod_virtual_disk#5&2fc68f79&0&000000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b} is not allowed.
1/4 18:12:08.074 364 error: assertion failed: c:\_starwind\_v5\_release_60\starwind\service\common\fn_common.cpp:28 (isEmpty())
1/4 18:12:08.074 364 SPTI: '\\?\ide#cdromnecvmwar_vmware_ide_cdr10_______________1.00____#5&3a794e10&0&1.0.0#{53f56308-b6bf-11d0-94f2-00a0c91efb8b}': ' NECVMWar VMware IDE CDR10 1.00': adapter 1, bus 1, target 0, LUN 0; maxTransferLength 131072, alignmentMask 0x1
1/4 18:12:08.074 364 Srv: Found SPTI device '\\?\ide#cdromnecvmwar_vmware_ide_cdr10_______________1.00____#5&3a794e10&0&1.0.0#{53f56308-b6bf-11d0-94f2-00a0c91efb8b}': ' NECVMWar VMware IDE CDR10 1.00'
Fri Jan 04, 2013 5:35 pm
Why don't you stick zipped log into your message or send it zipped to support@starwindsoftware.com ?
http://www.starwindsoftware.com/forums/ ... -t740.html
The one you've copypasta'd is truncted leaving us to guess what's actually going on...
laki78
Fri Jan 04, 2013 5:49 pm
OK, I send log file by e-mail and also attached to this message.
starwind.zip
(29.5 KiB) Downloaded 891 times
Wed Jan 09, 2013 1:15 pm
Just keeping updated: the logs were forwarded to R&D and we are currently investigating the issue
