I'm getting an error while I try to connect to the target. On the Equallogic, I have a volume assigned an iSCSI target, with no restrictions (accepts all connections from any initiator name, accepts all connections from any IP address, and has no CHAP authentication requirement). Ultimately, if I can get this working, I need to apply at least a CHAP authentication restriction, but I wanted to rule out any causes of problems before I moved forward.
The OS I'm using is Windows Server 2012, and its default initiator connects perfectly. The reason I want to use the Starwind initiator is that I'm having I/O performance issues in VMs hosted on the iSCSI-connected volume, and I heard that Starwind has caching for its initator that might improve performance. The error and log file are as follows:
"An error occurred during installation of the device.
Creation of the iSCSI device failed with all the addresses supplied by the server."
12/5 10:59:38.670 >> CLanguager::LoadLanguage(language=0x409)
12/5 10:59:38.678 >> CStarPortAPI::CStarPortAPI()
12/5 10:59:38.678 >> CStarPortAPI::DriverOpen()
12/5 10:59:38.678 >> CStarPortAPI::DriverVersion(...)
12/5 10:59:38.678 CStarPortAPI::DriverVersion: Calling STARPORT_IOCTL_GET_VERSION
12/5 10:59:38.679 CStarPortAPI::DriverVersion: Calling DeviceIoControl(...)
12/5 10:59:38.679 CStarPortAPI::DriverVersion: Input: ApiVersion = 30001
12/5 10:59:38.679 CStarPortAPI::DriverVersion: Output: Version = 20110316, API = 30001, DriverOpenContext = 0, DriverInstance = FFFFFA800D17F060
12/5 10:59:38.679 CStarPortAPI::CStarPortAPI: StarWind iSCSI Initiator version: 20091223; StariSCSI driver: API v30001, Build 0x20110316
12/5 10:59:38.679 >> CDriveLetterMap::CDriveLetterMap()
12/5 10:59:38.680 >> CStarPortDoc::CStarPortDoc()
12/5 10:59:38.740 >> CStarPortView::OnInitialUpdate()
12/5 10:59:38.740 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
12/5 10:59:38.754 >> CStarPortDoc::ResyncRegistryAndDriverContents(bAutomountDevices=1)
12/5 10:59:38.754 >> CStarPortAPI::GetDevices(...)
12/5 10:59:38.755 CStarPortAPI::GetDevices: Calling STARPORT_IOCTL_TARGET_LIST
12/5 10:59:38.755 CStarPortAPI::GetDevices: Output buffer:
12/5 10:59:38.755 CStarPortAPI::GetDevices: NumberOfTargets = 0
12/5 10:59:38.825 CStarPortApp::InitInstance: Showing mainform.
12/5 10:59:39.142 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
12/5 10:59:39.542 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
12/5 10:59:39.943 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
12/5 10:59:40.344 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
12/5 10:59:40.744 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
12/5 10:59:41.146 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
12/5 10:59:41.547 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
12/5 10:59:41.688 >> CStarPortAPI::GetTargets(dwIPAddress=0xC0A8C8DC, DWORD dwPort=3260, listTargets=...)
12/5 10:59:41.689 CStarPortAPI::GetTargets: Calling STARPORT_IOCTL_GET_TARGETS
12/5 10:59:41.689 CStarPortAPI::GetTargets: Input buffer:
12/5 10:59:41.689 CStarPortAPI::GetTargets: ServerAddress = #iscsi:192.168.200.220:3260
12/5 10:59:41.689 CStarPortAPI::GetTargets: Parameter[0] = InitiatorName=iqn.2003-06.com.starwindsoftware.starport:gnwhyperv01
12/5 10:59:41.702 CStarPortAPI::GetTargets: Output buffer:
12/5 10:59:41.702 CStarPortAPI::GetTargets: TargetsInfo[0] = TargetName=iqn.2001-05.com.equallogic:4-52aed6-b322cadb4-94dd73af8e750b3e-vss-control
12/5 10:59:41.703 CStarPortAPI::GetTargets: TargetsInfo[1] = TargetAddress=192.168.200.220:3260,1
12/5 10:59:41.703 CStarPortAPI::GetTargets: TargetsInfo[2] = TargetName=iqn.2001-05.com.equallogic:4-52aed6-9f22cadb4-a9bd73af8f550b3f-sanvolume1
12/5 10:59:41.703 CStarPortAPI::GetTargets: TargetsInfo[3] = TargetAddress=192.168.200.220:3260,1
12/5 10:59:41.703 CStarPortAPI::GetTargets: TargetsInfo[4] = TargetName=iqn.2001-05.com.equallogic:4-52aed6-8842cadb4-6c1d73af8f850b68-sanvolume2
12/5 10:59:41.704 CStarPortAPI::GetTargets: TargetsInfo[5] = TargetAddress=192.168.200.220:3260,1
12/5 10:59:41.704 CStarPortAPI::GetTargets: TargetsInfo[6] = TargetName=iqn.2001-05.com.equallogic:4-52aed6-b9d2cadb4-a3fd73af8fb50b7a-sanvolume3
12/5 10:59:41.704 CStarPortAPI::GetTargets: TargetsInfo[7] = TargetAddress=192.168.200.220:3260,1
12/5 10:59:41.704 CStarPortAPI::GetTargets: TargetsInfo[8] = TargetName=iqn.2001-05.com.equallogic:4-52aed6-8662cadb4-5c5d73afb8150be6-temp
12/5 10:59:41.705 CStarPortAPI::GetTargets: TargetsInfo[9] = TargetAddress=192.168.200.220:3260,1
12/5 10:59:41.705 >> CStarPortAPI::AddTargetToList(target=..., listTargets=...)
12/5 10:59:41.706 >> CStarPortAPI::AddTargetToList(target=..., listTargets=...)
12/5 10:59:41.706 CStarPortAPI::GetTargets: Server at IP:0xC0A8C8DC, Port:3260 returned the following targets:
12/5 10:59:41.706 CStarPortAPI::GetTargets: TargetName:iqn.2001-05.com.equallogic:4-52aed6-8662cadb4-5c5d73afb8150be6-temp
12/5 10:59:41.706 CStarPortAPI::GetTargets: TargetAddress: IP:0xC0A8C8DC, Port:3260
12/5 10:59:41.707 CStarPortAPI::GetTargets: TargetName:iqn.2001-05.com.equallogic:4-52aed6-8842cadb4-6c1d73af8f850b68-sanvolume2
12/5 10:59:41.707 CStarPortAPI::GetTargets: TargetAddress: IP:0xC0A8C8DC, Port:3260
12/5 10:59:41.707 CStarPortAPI::GetTargets: TargetName:iqn.2001-05.com.equallogic:4-52aed6-9f22cadb4-a9bd73af8f550b3f-sanvolume1
12/5 10:59:41.708 CStarPortAPI::GetTargets: TargetName:iqn.2001-05.com.equallogic:4-52aed6-b322cadb4-94dd73af8e750b3e-vss-control
12/5 10:59:41.708 CStarPortAPI::GetTargets: TargetAddress: IP:0xC0A8C8DC, Port:3260
12/5 10:59:41.708 CStarPortAPI::GetTargets: TargetName:iqn.2001-05.com.equallogic:4-52aed6-b9d2cadb4-a3fd73af8fb50b7a-sanvolume3
12/5 10:59:41.948 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
12/5 10:59:42.049 CWPPiSCSITargetSelection::CreateDevice: Trying to add an iSCSI device using TargetName=iqn.2001-05.com.equallogic:4-52aed6-8662cadb4-5c5d73afb8150be6-temp, IP:0xC0A8C8DC, Port:3260
12/5 10:59:42.049 >> CStarPortAPI::CStarPortAPI()
12/5 10:59:42.049 >> CStarPortAPI::DriverOpen()
12/5 10:59:42.050 >> CStarPortAPI::DriverVersion(...)
12/5 10:59:42.050 CStarPortAPI::DriverVersion: Calling STARPORT_IOCTL_GET_VERSION
12/5 10:59:42.050 CStarPortAPI::DriverVersion: Calling DeviceIoControl(...)
12/5 10:59:42.050 CStarPortAPI::DriverVersion: Input: ApiVersion = 30001
12/5 10:59:42.050 CStarPortAPI::DriverVersion: Output: Version = 20110316, API = 30001, DriverOpenContext = 0, DriverInstance = FFFFFA800D17F060
12/5 10:59:42.051 CStarPortAPI::CStarPortAPI: StarWind iSCSI Initiator version: 20091223; StariSCSI driver: API v30001, Build 0x20110316
12/5 10:59:42.052 >> CStarPortDoc::CreateiSCSIDevice(IP=0x309DFA8, Port=3260, TargetName=iqn.2001-05.com.equallogic:4-52aed6-8662cadb4-5c5d73afb8150be6-temp, Flags=0)
12/5 10:59:42.052 >> CStarPortAPI::InsertiSCSIDevice(dwIPAddress=0xC0A8C8DC, dwPort=3260, szInitiaotrName=iqn.2003-06.com.starwindsoftware.starport:gnwhyperv01, szTargetName=iqn.2001-05.com.equallogic:4-52aed6-8662cadb4-5c5d73afb8150be6-temp, szAdditionalParameter=, nTargetID=...)
12/5 10:59:42.052 CStarPortAPI::InsertiSCSIDevice: Calling STARPORT_IOCTL_TARGET_MOUNT
12/5 10:59:42.052 CStarPortAPI::InsertiSCSIDevice: Input buffer:
12/5 10:59:42.053 CStarPortAPI::InsertiSCSIDevice: Flags = 0
12/5 10:59:42.053 CStarPortAPI::InsertiSCSIDevice: ServerAddress = #iscsi:192.168.200.220:3260
12/5 10:59:42.053 CStarPortAPI::InsertiSCSIDevice: Parameter[0] = InitiatorName=iqn.2003-06.com.starwindsoftware.starport:gnwhyperv01
12/5 10:59:42.053 CStarPortAPI::InsertiSCSIDevice: Parameter[1] = TargetName=iqn.2001-05.com.equallogic:4-52aed6-8662cadb4-5c5d73afb8150be6-temp
12/5 10:59:42.060 CStarPortAPI::InsertiSCSIDevice: Session failed, status == 1326 !
12/5 10:59:42.061 >> CStarPortAPI::~CStarPortAPI()
12/5 10:59:42.061 CWPPiSCSITargetSelection::CreateDevice: Exception caught: Logon to the server failed.
12/5 10:59:42.061 CWPPiSCSITargetSelection::CreateDevice: Failed to connect to create iSCSI device using TargetName=iqn.2001-05.com.equallogic:4-52aed6-8662cadb4-5c5d73afb8150be6-temp, IP:0xC0A8C8DC, Port:3260
12/5 10:59:42.061 CWPPiSCSITargetSelection::CreateDevice: Creation of the iSCSI device failed with all the addresses supplied by the server.
12/5 10:59:42.062 CWPPiSCSITargetSelection::CreateDevice: Exception caught: Creation of the iSCSI device failed with all the addresses
12/5 10:59:42.349 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
12/5 10:59:42.750 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
12/5 10:59:43.151 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
12/5 10:59:43.552 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
12/5 10:59:43.952 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
12/5 10:59:44.352 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
12/5 10:59:44.754 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
12/5 10:59:45.154 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
12/5 10:59:45.555 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
12/5 10:59:45.956 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
12/5 10:59:46.356 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
12/5 10:59:46.758 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
12/5 10:59:47.159 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
12/5 10:59:47.560 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
12/5 10:59:47.960 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
12/5 10:59:48.361 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
12/5 10:59:48.632 Found language dll: language id: 0x0409 (English (United States)).
12/5 10:59:48.762 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
12/5 10:59:49.163 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
12/5 10:59:49.563 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
12/5 10:59:49.965 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
12/5 10:59:50.365 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
12/5 10:59:50.766 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
