What is the max settable "Snapshot Creation Period"?
mardes
Sat Dec 01, 2012 2:49 pm
Seems existing some problem setting high "Snapshot Creation Period" on CDP devices.
I need:
- max 2 snapshot
- Snapshot Creation Period of 15 days.
So I've defined Snapshot Creation Period (minutes) = 21600.
The problem is that after 30 minutes, the first snapshot has fired.
So, seems that a high value is ignored and, instead, is considered a default of 30'.
Is this correct?
Mon Dec 03, 2012 11:32 am
Hi! Just want to let you know that currently we are trying to reproduce your issue in our test lab. As soon as I`ll hear anything back from QA I`ll get back to you.
Thank you
Tue Dec 04, 2012 8:47 am
Can I ask you to send the logs on the date/time of the issue to support@starwindsoftware.com (I`ll appreciate if you`ll specify the time that we should look at in them as well)?
