Delayed Write Failed and drive not ready for access on aoe
danjaman
Mon Oct 22, 2012 8:21 pm
StarAoE Service v5.5 (Build 20091120, WinXP x86) on a Windows Server 2003 R2 SP1. On a mirror array on a Coraid Chassis, Disk are all healthy, MTU is at 9000 with jumbo frames activated on both (network card + switch).
We have multiples error on my aoe drive :
{Delayed Write Failed}
The device, \Device\Harddisk1, is not ready for access yet.
And my event viewer is full of these and it's erratic.
I need to do a chkdsk every 2-3 days because a my ntfs table is getting corrupted.
Anyone have a hint or know what may cause this problem ?
Thanks a lot
Tue Oct 23, 2012 11:15 am
Can you check the logs if you have some hardware issues/failures please?
danjaman
Tue Oct 23, 2012 1:00 pm
I have nothing on the starwind initiator log and theses two error (from initial post) in my event viewer.
Thanks for the reply, really appreciated
Tue Oct 23, 2012 4:56 pm
They are not related to initiator BTW. It means initiator cannot wire the data to target so it looks like it's a target / network issue.
What do you use as a target? Also try to check network connectivity. And increase disk timeout values:
http://blogs.msdn.com/b/san/archive/201 ... value.aspx
Let us know about results. That's it...
danjaman wrote:I have nothing on the starwind initiator log and theses two error (from initial post) in my event viewer.
